| Bob L. |
Jun 30 2012, 01:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I'm still taking apart my new (to me) '76 2.0 for cleaning and I have the fan shroud laid bare with all screws removed. The edges all are free to separate.
There seems to be a pin in the middle of the body of the unit which is holding it together. ![]() Do the halves separate or is it just a tease? |
| JStroud |
Jun 30 2012, 02:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
It does split into two, there are alignment pins that hold it together, if all the fasteners have been removed, some careful prying should get it to separate.
Good luck Jeff |
| tomeric914 |
Jun 30 2012, 02:16 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Don't force it apart. Find all of the nuts and bolts holding the halves together. It may take some digging due to dirt and grease buildup.
| Bob L. |
Jun 30 2012, 03:41 PM
It does split into two, there are alignment pins that hold it together, if all the fasteners have been removed, some careful prying should get it to separate. Good luck Jeff I can only see the one pin. I'll double check to ensure all fasteners are removed. I'll use some wood wedges to try to separate the halves. gentle taps! |
Lo-Fi Version | Time is now: 9th March 2026 - 10:02 PM |
