kbrunk1 |
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States ![]() |
I can get new fuel 12 mm lines for $2.50 per foot.
Do you have to use the rubber fuel lines with the braided jacket? Thanks |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
vacuum lines
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
No you do not. Only reason to stick with the braided cloth line, would be to keep the original look. The rubber fuel line should work just as well for your vacuum lines.
ape914 |
red locktite ![]() ![]() Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None ![]() |
unbraided hose in vacuum service might tend to collapse more than braided hose might collapse, maybe, maybe not???? suck on closed off section of hose and see how much it collapses, if it passes this test, then i see no reason fuel hose wont work. braided hose does look nicer however, but that may not be important to you.
Lo-Fi Version | Time is now: 13th June 2024 - 09:56 PM |
