The Bee Flies! |
The Bee Flies! |
Rusty |
Oct 21 2004, 03:39 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Well, today was the first time in quite a while I've been able to work on the Bee. It was put away last summer, not driven during the winter or while I was in Iraq.
Today, I installed new plugs, coil, colorful vacuum line set and a rebuilt MPS. //edit// Also squirted some oil in each cylinder. // I flushed the old gas out by jumping the fuel pump relay, and filled the tank with 5 fresh gallons of gas. (IMG:style_emoticons/default/w00t.gif) It fired right up! It idles a bit high (~2800 rpm). No vacuum leaks. Unplugging the hose on the back of the MPS, and the idle drops to about 1000 rpm. Any ideas? -Rusty (IMG:style_emoticons/default/smoke.gif) |
Bleyseng |
Oct 21 2004, 03:51 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Good to hear its running. Should just be that you hooked up a vacuum hose wrong.
Do a search for the pic of the 73 2.0l hose layout. I can't post it from here at work (dialup). Geoff |
Howard |
Oct 21 2004, 04:10 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
This one?
Attached image(s) |
Rusty |
Oct 21 2004, 04:19 PM
Okay.. some troubleshooting has shown that I'm pulling LOTS of air through the AAR.
The AAR is pulling lots of air from the air cleaner. When I pull the vacuum line and plug it, RPMs drop down to the 1200 range. Is there a test for the AAR? I remember something about how they could be stuck open? -Rusty (IMG:style_emoticons/default/smoke.gif) |
Rusty |
Oct 21 2004, 04:22 PM
This is basically what my layout looks like... except I only have one nipple on my throttle body (the one that has the blue hose isn't on my TB).
-Rusty (IMG:style_emoticons/default/smoke.gif) Attached thumbnail(s) |
phantom914 |
Oct 21 2004, 04:27 PM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
QUOTE(Lawrence @ Oct 21 2004, 02:19 PM) Okay.. some troubleshooting has shown that I'm pulling LOTS of air through the AAR. The AAR is pulling lots of air from the air cleaner. When I pull the vacuum line and plug it, RPMs drop down to the 1200 range. Is there a test for the AAR? I remember something about how they could be stuck open? -Rusty (IMG:style_emoticons/default/smoke.gif) Check the wire going to the AAR for voltage. That wire is to heat up an internal element in the AAR which should close the vavle within a few minutes after starting. If it has voltage and the AAR is still passing air after several minutes, it is bad. Andrew |
Howard |
Oct 21 2004, 04:45 PM
Shot in the dark. Is vacuum hose (lowest gray one in your diagram) to decel valve ok? That's the only way my idle revs to up like that. Back hose in this pic.
Attached image(s) |
Bleyseng |
Or after the car is running for 5 minutes the bottom of the AAR should be quite warm. If it is then you gots + power to it aaannd its stuck from rust. Shoot a liberal amount of PB Blaster into it and let it soak over night to free it. Not WD40!
Sooo, how does the Bee drive? Should go like a bat outtahell now. Geoff |
Rusty |
Oct 21 2004, 04:59 PM
That unit is sucking LOTS of air... so I suspect it might be stuck open as well as not connected. It's pretty obvious that the AAR didn't get as warm as other items in the engine compartment.
Looks like I need to check the wiring in the morning... and spray it down with PB Blaster if it turns out to be disconnected. Thanks for all the good advice. I'm not going to drive it until I get this settled! Time for dinner! (IMG:style_emoticons/default/chowtime.gif) -Rusty (IMG:style_emoticons/default/smoke.gif) |
Curvie Roadlover |
Oct 21 2004, 05:56 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
You could just plug it closed at the hose. You only really need the AAR for really cold ( < 32 degrees ) starts. I heard another way you can check if it's stuck is to put it in a hot oven for a while. The valve should close from the heat regardless of whether or not the heating element in it is working.
phantom914 |
Oct 21 2004, 10:58 PM
QUOTE(Curvie Roadlover @ Oct 21 2004, 03:56 PM) You could just plug it closed at the hose. You only really need the AAR for really cold ( < 32 degrees ) starts. I heard another way you can check if it's stuck is to put it in a hot oven for a while. The valve should close from the heat regardless of whether or not the heating element in it is working. I think you may be thinking of the cold start injector, which does not kick in until <32 deg.? You could drive without the AAR of course. You just might have to keep your foot on the throttle at idle until the engine warms up due to a low idle speed. Andrew |
Lo-Fi Version | Time is now: 31st May 2024 - 11:57 PM |
