914 2.0 FI Vacuum Line In Block Plug Came Out |
kbrunk1 |
Jul 27 2012, 08:28 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
any suggestions to get this "glued" back into the block.
What kind of glue? Attached thumbnail(s) |
TheCabinetmaker |
Jul 27 2012, 08:40 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Looks like its been rtv'd back in once. You might a use light dab of jbweld, but the proper way would be to increase the diameter of the tube. They look like they were a press fit originally. Maybe a tapered rod of some sort. Another option would be to tap the hole and use a brass plumbing fitting. Thats what we do with the late model heads to add the vents.
JeffBowlsby |
Jul 27 2012, 08:50 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Just slightly ovalize it and tap it in. Its just a friction fit.
Lo-Fi Version | Time is now: 9th June 2024 - 04:21 PM |
