Fuel Pump, Switch to NAPA's 2 outlet pump |
sbruzek |
Aug 8 2012, 08:07 PM
Newbie Group: Members Posts: 35 Joined: 17-January 12 From: United States Member No.: 14,024 Region Association: Upper MidWest |
Any good reason not to switch over to a 2 outlet fuel pump?? NAPA has one for only $100 or so. What the function of the 3 rd port on the original fuel pump??
76-914 |
Aug 8 2012, 10:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
NAPA has them for < $50. Do a search here. IRRC, it's a Ford pump.
Dave_Darling |
Aug 8 2012, 10:51 PM
The third fitting on the stock 70-74 pump is to dump excess fuel back into the return line. I don't think it's really needed, myself--the fuel pressure regulator appears more than capable enough of dealing with all of the fuel that needs to go back to the tank.
As long as the pressure and volume are reasonable, the less expensive pump should work fine. You may have to do some Adaptor Majik to plumb it. --DD |
Thestigz06 |
Aug 8 2012, 11:32 PM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
Being that an arm, leg and first born child is wanted for a working 3 port fuel pump there days i went with a pump similar to the youre refering to(just didnt buy it from napa). No problems with it at all!
Hope this helped you! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:44 AM |
