CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
I got my heads converted from single to double valve springs.
Now I am putting the 9550 Cam setup in my engine and was wondering if I can just convert them over to the HD Valve Springs that come with the Kit or not? Len Hoffman said I should use "Crowler Springs" I never heard of them and was wondering if anybody can tell me something about them? Or are there any other solutions? ![]() ![]() |
CG-914 |
I meant Crower Springs (IMG:style_emoticons/default/lol-2.gif)
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
I would strongly recommend you accept Len Hoffman's suggestion. He's a total PRO and knows which springs work with which cams. If the springs aren't specified to work with the lift of your cam/ RPM you motor is designed to turn/ lifters and rockers, you will likely experience valve float. Not a good thing. In fact check the entire design of your heads with Len before you put them on the motor. |
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
You, NEVER EVER, don't do what Len Hoffman ,tells you to do with Type 4 Heads!! NEVER EVER !!! " As it is said so shall It be Written' !!!! Dave (IMG:style_emoticons/default/slap.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
www.crower.com
Been around since dirt. |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Well, I expect that Jake sent you the correct springs if you purchased the super kit. Isn't that his point of his cam program?
Based on a post that Jake made regarding 9550 cam, you run out of cam at around 6200. I find it hard to believe that you could float the valves unless unless you missed 3rd on a downshift and caught 1st. If you indeed purchased the super kit add-on, I would swap them out. Otherwise, I would run them. I don't think the the manufacturing process for lifters or cams changes based on the grind. Carlos |
SLITS |
Not knowing what springs that were recommended, we used Chevy dual springs on the race car.
We also had a spring tester so we could determine the length of the installed spring for the seat pressure and over the nose pressure we wanted (valve train control). Further, we would polish the ends of the spring and run washers underneath to avoid the sharp edges of the spring cutting into the head. Lastly, I hope you have the figures for installed height and avoidance of coil bind on compression of the spring. A lot more to it than just running "dual springs". |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
I already went over this with Cornelius (twice), but I'll share it with everyone else so you'll understand why I recommended switching to the crower springs and not using the single springs that come with Jake's kit. The single springs that Jake sells are fine springs.
The heads have already been cut for dual springs. The type of dual springs that he's been using are interference springs that locate in the heads off the inner spring. And the outer springs have the same dimensions as Jake's single springs. If the inner spring is eliminated the outer will have no boss to align it and it will float around. The crower springs that I recommended have a larger O.D. and will locate in the head firmly and allow no shuffling. |
CG-914 |
I already went over this with Cornelius (twice), but I'll share it with everyone else so you'll understand why I recommended switching to the crower springs and not using the single springs that come with Jake's kit. The single springs that Jake sells are fine springs. The heads have already been cut for dual springs. The type of dual springs that he's been using are interference springs that locate in the heads off the inner spring. And the outer springs have the same dimensions as Jake's single springs. If the inner spring is eliminated the outer will have no boss to align it and it will float around. The crower springs that I recommended have a larger O.D. and will locate in the head firmly and allow no shuffling. Hi Len, I do believe that what you recommend is the best with the incredible reputation you have! That is also what I want, but I have to at least look for plan B because spending $1300 for a 23 year old student is somewhat impossible (IMG:style_emoticons/default/dry.gif) Thank you for all your help so far though!!! (IMG:style_emoticons/default/pray.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
The heads have already been cut for dual springs. The type of dual springs that he's been using are interference springs that locate in the heads off the inner spring. And the outer springs have the same dimensions as Jake's single springs. If the inner spring is eliminated the outer will have no boss to align it and it will float around. (IMG:style_emoticons/default/agree.gif) once you cut for dual springs you can't go back. |
Lo-Fi Version | Time is now: 8th July 2025 - 04:18 PM |
