seems like a lot of carb issues of late, i forgot all about these. they're never mentioned |
rhodyguy |
Aug 15 2012, 10:04 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
while looking a a weber 40 for some jetting sizes for hotshoe i unscrewed the brass nut on the bottom of the fuel inlet. if you're running carbs and are chasing persistent problems with little or no success i suggest you check the screens that may or may not be inside of the fuel inlets. best checked on a cold engine as there will prob be fuel in the inlets. hope this helps someone. i'm soaking the brass screen in some lemon juice to see if the screen cleans up. if this works i'll post another picture. i squeezed these 2 out of the camera just before the bat died.
k Attached thumbnail(s) |
02loftsmoor |
Aug 15 2012, 01:17 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
why don't you use carb cleaner works better
rhodyguy |
Aug 16 2012, 10:16 AM
non toxic, no fumes. add a little water, some sugar. a glass and ice cubes and i could drink it. no run to the parts store for a $4+ can of spray. actually, the screen and the bottom of the fuel inlet had no debris and what looks like yuck in the screen was oxidation. it cleaned up nicely.
k |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:16 PM |
