| watsonrx13 |
Oct 24 2004, 02:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, Joe Ricard has just informed me that he's received the new lifters for my rebuild. They are the Web-Cam Performance Lifters, ordered through PP, as recommended for the Web-Cam camshaft for carbureted cars.
Is this good, bad, correct, wrong? I'm confused (IMG:style_emoticons/default/blink.gif) Do I need to call PP and get an exchange? If I should get an exchange, what should I order? This car is going to be a driver with occasional AX runs. Joe is rebuilding the engine, it's a 2.0l with 94mm P/C, twin 40 IDF, 9.2:1 CR. I'm looking for reliability and dependibility. |
| MattR |
Oct 24 2004, 02:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
I think the consensus is: stay away from hydraulic lifters.
Im running a very similar setup (9.2 cr, 44idfs, etc), and I went with a web 494 grind and solid lifters. |
| F4i |
Oct 24 2004, 02:18 PM
914 DOG! ![]() ![]() Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
are you sure they are hyd. lifters? The "solid" ones are two piece.
| Demick |
Oct 24 2004, 05:56 PM
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
The new solid lifters are 2-piece. Shake them and they will rattle (hydraulic ones won't rattle, but look very similar). Do a search here on lifters. There have been reported problems with the new lifters either breaking or causing the cam to go flat within the first few hours of running. But in most cases they are probably fine. I decided that I couldn't risk my engine on questionable lifters and put in ceramic ones from LN Engineering instead.
Demick |
| Joe Ricard |
Oct 24 2004, 06:48 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yup these rattle. So what's the deal never seen these before although I don't put engines together everyday.
Label on the box says 914 high performance lifters. Got a cir-clip holding the inside piece in. Anybody got an explaination how these work? |
| StratPlayer |
Oct 24 2004, 06:53 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,383 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Hey Dimick,,, were those ceramic lifters drop in or did you have machine work done to make them fit?????
| Jake Raby |
Oct 24 2004, 07:18 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I developed this
http://www.aircooledtechnology.com/lifters.htm To test lifters and camshafts as well as break them in prior to use so they could be inspected for wear.. There are no good conventional lifters out there.. Out of the 65 sets that we have tested 50 or so of them have had uneven wear, or signs of going flat. The problems are numerous and I'm still working to make it all better. Its to the point where EVERY engine we build gets ceramics- No risk taking here. The lifters you have thatare solid but rattle are web cam solid lifters. That two piece design is the reason we don't fancy them. I am working with another company to make an insert that will go inside the lifter and get rid of the rattles and lash issues that it can cause. This testing has sucked, after almost 8,000.00 worth of cams, lifters, and prototypes the problems still are not cured. The next step is Billetcams ground with more taper for a higher lifter surface speed, coupled with all components being fully micropolished to a mirror finish to to reduce friction and load points.... Nothing off the shelf is perfect these days with lifters. I have to get this straightened out because I'll starve if we don't! 8 months of backlog does no good if we can't assemble anything! |
| Demick |
Oct 24 2004, 07:29 PM
QUOTE(StratPlayer @ Oct 24 2004, 04:53 PM) Hey Dimick,,, were those ceramic lifters drop in or did you have machine work done to make them fit????? Drop-in. The early ones required machining (and maybe you can still buy ones that require it), but for the most part, they are all drop-in now. At least I am pretty sure about that. Give Charles at LN Engineering a call - he will give you the low down. Demick |
| SGB |
Oct 24 2004, 07:35 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Perhaps manufacturing quality isn't the same days....
I bought a web cam specifically ground for hydraulic lifters in 1989 that has been great for me for about 50 K miles. I've finally got it set truely "right" and the car is stronger, quieter, and cooler than it used to be. It still rattles more than solid lifters when started after sitting over two weeks. Even when mis-set, the valves "work", which may be part of the problem. After all, I put these in 15 years ago and just finally got the clearances right. But I thought that the hydro lifters had to be used with the right grind, and mine is a little higher lift and longer duration than stock, it isn't enough to get more than prolly 125 hp. I think Webcam used to have two hydrualic grinds recommended when I bought mine. (IMG:style_emoticons/default/driving-girl.gif) |
Lo-Fi Version | Time is now: 20th September 2026 - 11:35 AM |
