| jsayre914 |
Aug 19 2012, 04:01 PM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Can you show me on this picture where you would clean, and with what.
Also where to lubricate and with what. Thanks (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
| 914Sixer |
Aug 19 2012, 07:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,466 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I would probably just wipe them out good. Spray some electrical contact cleaner. Make sure the contact points are clean and not pitted. Lube the pivot shafts with distributor grease.
| Dave_Darling |
Aug 20 2012, 12:35 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Clean the metal contact bits. Clean the plastic rubbing blocks. Clean the pivots and so on. Clean the electrical contacts inside the plug with TV tuner cleaner (or equivalent). Re-lube the pivots and put a dot of the super-sticky distributor grease on each of the plastic rubbing blocks.
--DD |
| jsayre914 |
Dec 12 2012, 03:17 PM
Im not sure if its alignment or what. I am still getting an occasional loss of power (bucking) under heavy accleration. No bucking under constant speed at any RPM, no bucking if im driving around town, even quick. Only noticable when I am on the Highway at speed and then I floor it. TPS is good, and accleration is smooth other than this highway bucking.
Do I need more lube on the triggerpoints? This is my second used set. Are there any available new? I adjusted them to look center. is there a way to adjust with tools? I am gonna bet my problem is trigger related (IMG:style_emoticons/default/popcorn[1].gif) |
| 914itis |
Dec 12 2012, 04:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Joe, Did you check the vacuum advance on the dizzy to make sure that the arms are moving properly?
| porschepartguy |
Dec 12 2012, 04:20 PM
Newbie ![]() Group: Members Posts: 2 Joined: 12-December 12 From: California Member No.: 15,252 Region Association: None |
I have NOS, Bosch # 1 230 090 000 trigger points. $100 shipped.
if interested, please email: porschepartguy@gmail.com Best, John |
| TheCabinetmaker |
Dec 12 2012, 04:39 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,375 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Save your hundred bucks. What you describe is not a trigger point problem.
| sfrenck |
Dec 12 2012, 04:48 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
Save your hundred bucks. What you describe is not a trigger point problem. And the problem is..... (IMG:style_emoticons/default/WTF.gif) |
| TheCabinetmaker |
Dec 12 2012, 05:26 PM
Bucking is almost always caused by a rich fuel condition. Happening at wot would point me toward the MPS.
| jsayre914 |
Dec 12 2012, 05:31 PM
Bucking is almost always caused by a rich fuel condition. Happening at wot would point me toward the MPS. (IMG:style_emoticons/default/idea.gif) I did notice the AFR gauge drops off the lean end for a milisecond with each buck. |
| jsayre914 |
Dec 13 2012, 04:42 PM
Hey, i was just thinking. Its been about 3000 miles since my last valve adjustment. I will adjust this weekend. Since this problem came on about a week ago, i was wondering if it could just be symptom of a needed adjustment
| mepstein |
Dec 13 2012, 09:50 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,629 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Bucking is almost always caused by a rich fuel condition. Happening at wot would point me toward the MPS. What if it's happening at any throttle position? (I've been trying to trouble shoot a bucking problem for a while now.Sometimes it's fine, sometimes it's terrible). |
| McMark |
Dec 14 2012, 03:34 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Didn't see anyone mention TPS. Try unplugging it and seeing if the problem persists. Your acceleration will be decreased, but it'll run 'fine'.
| john rogers |
Dec 14 2012, 04:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
In all the years we had a 2L with trigger points (10?), we never found cleaning/lubing/etc to them did anything. The only thing that worked was putting in new ones and generally that was done after everything else was adjusted, poked, replaced, etc and the problem never went away but new points "magically" fixed it! This may be against what many will say but the replacement ALWAYS fixed the problem.
Since you said the O2 dropped low, I would suggest installing a fuel pressure gauge and run it up through the engine lid so someone can watch it. The engine is a bit larger and it sounds like to me there is not enough fuel being caused by pressure surges. We used a gauge that was left in all the time and now and then I would run the pressure up and down just to "clean out" the pressure regulator. Seemed to help. A note, if you unplug anything, make sure the hoses are well plugged so an air leak does not mask the issue. |
| jsayre914 |
Dec 14 2012, 04:13 PM
In all the years we had a 2L with trigger points (10?), we never found cleaning/lubing/etc to them did anything. The only thing that worked was putting in new ones and generally that was done after everything else was adjusted, poked, replaced, etc and the problem never went away but new points "magically" fixed it! This may be against what many will say but the replacement ALWAYS fixed the problem. Since you said the O2 dropped low, I would suggest installing a fuel pressure gauge and run it up through the engine lid so someone can watch it. The engine is a bit larger and it sounds like to me there is not enough fuel being caused by pressure surges. We used a gauge that was left in all the time and now and then I would run the pressure up and down just to "clean out" the pressure regulator. Seemed to help. A note, if you unplug anything, make sure the hoses are well plugged so an air leak does not mask the issue. I do have a fuel gauge in the cabin it holds steady @30psi under any and all conditions, needle dosnt even wiggle. Im thinking trigger points |
| porschepartguy |
Dec 14 2012, 08:06 PM
Hey Joseph, My partner will be at the shop tomorrow to pick up the trigger points. He will call you then and send paypal request. Thanks John |
| Dave_Darling |
Dec 14 2012, 10:18 PM
If you have access to an oscilloscope, you can scope the trigger point signals to see if they're noisy or bouncing.
--DD |
Lo-Fi Version | Time is now: 15th April 2026 - 09:14 AM |
