Issue Installing the 911 Timing Chain Tensioner Update |
map |
Aug 21 2012, 10:51 AM
Pieper Group: Members Posts: 89 Joined: 29-May 09 From: Manitou Springs CO Member No.: 10,420 Region Association: Rocky Mountains |
Kevin and I are having an issue installing the update kit I purchased from Pelican. The oil line on the right side seems to be an inch short. We tried stretching it, but can't get it to reach.
Has anyone else had a similar issue installing this kit? If so, what was your solution? Thanks in advance. Pieper |
gothspeed |
Aug 21 2012, 11:03 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
The pressure sender fitting makes up the difference.
Attached image(s) |
Ferg |
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
You need the oil pressure sender and mounting block to take up that space.
SLITS |
Aug 21 2012, 11:25 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Kirmizi |
Aug 21 2012, 12:18 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Wait.... Kevin's working on a carb'd engine? (IMG:style_emoticons/default/biggrin.gif)
Mike |
toolguy |
Aug 21 2012, 12:20 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
this is what you need. . . I'll send you a PM
Attached image(s) |
sixnotfour |
Aug 21 2012, 01:15 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
you dont need all that, there is a simple extension. used to be a weltmeister thingy.
here you go; http://www.automotion.com/tensioner-adapte...-1967-1973.html |
map |
Aug 22 2012, 05:21 PM
Nope, 2.7 w/ CIS Thanks guys. It's usually my wife that points out things this obvious. Pieper PS I share Kevin's bias towards FI. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:43 AM |
