> speedo needle, wobbly needle
cal914
post Aug 29 2012, 03:07 PM
my needle on my speedo wobbles up and down when in use doesn't stay at its correct speed just bounces up and down what causes this
Replies(1 - 6)
underthetire
post Aug 29 2012, 03:40 PM
Bad cable
loose angle drive
Valy
post Aug 29 2012, 04:11 PM
Lube the cable. If it doesn't help, there is dirt in the magnetic pickup inside the speedometer. Try lubing the speeding input shaft as well.
skaufmann
post Aug 31 2012, 10:41 AM
Blissfully Ignorant
Some clarification needed.
-What lube should be used?
-What ends to lube? At speedo and/or at angle drive?
-How hard is it to remove the cable at the speedo?
Valy
post Aug 31 2012, 11:01 AM
QUOTE(skaufmann @ Aug 31 2012, 09:41 AM) *
Any oil is fine. Engine oil works well.
It's usually the speedo side that gets dry because its higher.
You literally pull the speedo and unscrew the cable end with your hand. Some electrical contacts may come loose before you notice so pay attention to the colors and locations.
Elliot Cannon
post Aug 31 2012, 11:15 AM
Group: Retired Members
It could be that the cable has broken strands and they are catching and releasing on the cable housing as the cable turns. A sharp kink in the cable will also cause this.
zeezee
post Aug 31 2012, 10:32 PM
I messed my speedo cable up when yanking on the gauge cluster. Must have pulled and tweeked it too hard or something. It would bounce +/- 10 MPH when under 40.
A new cable fixed it.
- Lo-Fi Version Time is now: 13th March 2026 - 12:34 AM
