> volt gauge
StratPlayer
post Aug 30 2012, 09:17 AM
StratPlayer
What is the main cause of a volt gauge showing a negative reading when the car is running?
Replies(1 - 5)
Valy
post Aug 30 2012, 09:33 AM
What do you read exactly?
There is no negative range on the gauge.
walterolin
post Aug 30 2012, 09:41 AM
Valy is correct. If it is a mechanical (d'Arsvonval) meter it will only read negative if it has a zero in the center. If it is digital (say a Fluke 179), and it is reading negative, you have the leads reversed.
Olin
post Aug 30 2012, 09:51 AM
If its the one in the console; just about anything. Because of its location in the "chain" it is basically starved for current. A 15w bulb activated will make it read below 12v.
Spoke
post Aug 30 2012, 11:24 AM
Jerry
The wires are backwards. The meter only has graduations for positive voltage. reverse the wires and and you measure negative voltage.
toolguy
post Aug 30 2012, 12:04 PM
please clarify your question before reversing any wires. . what do you mean 'reads negative' ?? is this a stock meter, reading from 0 up to whatever positive, or does it have a 0 in the middle and one side neg 12 and the other side pos 12??
If you reverse the leads inappropriately, you'll at best peg the needle and that can bend it. . the terminals on the rear of the meter should be labeled
This is when a picture is worth a thousand words. .
OR are you talking about a VOM hand held mult-meter. . If yes, then reverse the leads. . red to positive
- Lo-Fi Version Time is now: 16th April 2026 - 05:30 PM
