| pnewman |
Sep 12 2012, 11:20 AM
Member ![]() ![]() Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
So I have some nice looking floor mats. They sit on top of my carpeting. Only one small problem; after a while of driving they begin to bunch up on the accelerator pedal and keep my idle up. (IMG:style_emoticons/default/mad.gif) (See first / top pic)
I keep having to reach down under the front of my seat and pull them back. They have grommets for keepers but they don't line up with the stock pegs. (See middle pic) I was hoping to utilize the stock pegs. I have seen aftermarket generic clips (see Last / bottom pic). I was hoping to utilize the stock pegs... I was hoping that someone else has solved this problem and could make recommendations so as to avoid a trial and error experience for myself. Thanks in advance for the assistance. Pete (IMG:style_emoticons/default/smile.gif) Attached image(s)
| wingnut86 |
Sep 12 2012, 12:19 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Check JC Whitney. They used to have the oddball offerings similar to this. Also, some OEMs used to make extended carpet pins that also rotated 360° (don't know why) and had the modern hook type pin. You may have to call a auto carpet retailer to see wgat they know. Lastly, hit a pick'n'pull or similar and see what the donor cars of different makes have...
| pnewman |
Sep 12 2012, 02:51 PM
Check JC Whitney. They used to have the oddball offerings similar to this. Also, some OEMs used to make extended carpet pins that also rotated 360°[u] (don't know why) and had the modern hook type pin. You may have to call a auto carpet retailer to see wgat they know. Lastly, hit a pick'n'pull or similar and see what the donor cars of different makes have... The extending post type is something that I have seen before that I thought might work. I can't remember where however (IMG:style_emoticons/default/confused24.gif) rrrrr. Last resort is a U-pic-a-part. |
| DBCooper |
Sep 12 2012, 03:40 PM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Someone here sewed or glued a yoga mat (they come in all colors) onto the back of that carpet section to reduce noise and give it some structure. Looked like a simple and functional option.
| pnewman |
Sep 12 2012, 10:46 PM
found a newby ebay seller from Greece with a good looking product.
http://www.ebay.com/itm/Car-mat-fixing-cli...ies&vxp=mtr Attached thumbnail(s) |
| pnewman |
Sep 12 2012, 10:51 PM
I am considering a carpet screw specialty rivot. super simple.
| Mikey914 |
Sep 12 2012, 10:57 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I'm not real fond of anything that puts a hole throught the tar and metal. Any water penetration will have an opening to beneath the tar.
There has to be a better way. |
| blitZ |
Sep 13 2012, 05:19 AM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I made my own with a piece of coat hanger. I made a loop and screwed it to the seat mount. the other end hooks into the grommet. Works great, cost nothing.
| wingnut86 |
Sep 13 2012, 05:30 AM
I do like the solutions you found, especially the latter. Did the Greek site state US Dollars only, just wondering.
And, Mark has a good point as well. How would a sticky backed strip of heavy loop Velcro work? Seems like it would grab well, and could be pulled from the back edge of the carpet/matt connection when cleaning(?). |
| Bartlett 914 |
Sep 13 2012, 07:17 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
So I have some nice looking floor mats. They sit on top of my carpeting. Only one small problem; after a while of driving they begin to bunch up on the accelerator pedal and keep my idle up. (IMG:style_emoticons/default/mad.gif) (See first / top pic) I keep having to reach down under the front of my seat and pull them back. They have grommets for keepers but they don't line up with the stock pegs. (See middle pic) I was hoping to utilize the stock pegs. I have seen aftermarket generic clips (see Last / bottom pic). I was hoping to utilize the stock pegs... I was hoping that someone else has solved this problem and could make recommendations so as to avoid a trial and error experience for myself. Thanks in advance for the assistance. Pete (IMG:style_emoticons/default/smile.gif) Is it they do not align up or are the stock pins too short? If the pins are simply too short, Drill and tap them and use a screw and washer. |
| pnewman |
Sep 13 2012, 07:31 AM
So I have some nice looking floor mats. They sit on top of my carpeting. Only one small problem; after a while of driving they begin to bunch up on the accelerator pedal and keep my idle up. (IMG:style_emoticons/default/mad.gif) (See first / top pic) I keep having to reach down under the front of my seat and pull them back. They have grommets for keepers but they don't line up with the stock pegs. (See middle pic) I was hoping to utilize the stock pegs. I have seen aftermarket generic clips (see Last / bottom pic). I was hoping to utilize the stock pegs... I was hoping that someone else has solved this problem and could make recommendations so as to avoid a trial and error experience for myself. Thanks in advance for the assistance. Pete (IMG:style_emoticons/default/smile.gif) Is it they do not align up or are the stock pins too short? If the pins are simply too short, Drill and tap them and use a screw and washer. Ironically, I was originally planning on going your: drill, tap and bolt route. But alass the grommets on the carpet mats do not align. Nor do the stars on this one. I guess that I could add a second pair of grommets per mat but I think that it would look excessive. (IMG:style_emoticons/default/blink.gif) Thanks for the idea. |
| pnewman |
Sep 13 2012, 07:34 AM
I made my own with a piece of coat hanger. I made a loop and screwed it to the seat mount. the other end hooks into the grommet. Works great, cost nothing. I think that this is a good idea! hmmm. Interesting that this is the strongest recommendation of them all. A bit more laborious but how much time have I spent researching options! |
| pnewman |
Sep 13 2012, 07:37 AM
I'm not real fond of anything that puts a hole throught the tar and metal. Any water penetration will have an opening to beneath the tar. There has to be a better way. I couldn't agree more. I am definately NOT drilling a hole in my solid floor pans to secure floor a pair of floor mats! That is definately not a good idea. (IMG:style_emoticons/default/dry.gif) I do think however that the "pin screws" shown (the little specialty grommets with philips heads and plastic screw shanks below) would only screw into the carpet and rubber beneath and not through the metal floor. ...I think. |
| rhodyguy |
Sep 13 2012, 08:51 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
some stick on velcro?
k |
| Mikey914 |
Sep 13 2012, 10:37 AM
| dlestep |
Sep 13 2012, 11:32 AM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
| pnewman |
Oct 8 2012, 08:52 AM
I made my own with a piece of coat hanger. I made a loop and screwed it to the seat mount. the other end hooks into the grommet. Works great, cost nothing. Finished / Installed. I did almost exactly that... Bought raw mild steel wire rod. Bent cut welded the loop closed. spot welded the wire together to reinforce it. media blasted it. Primed and painted Heat shrinked the end that I would occasionally step on that also came into contact with the other metal (grommet) so as to minimize electrolisis. Used a stainless steel truss screw to secure it to the seat cross member. Pics to come. Works absolutely perfect! Plus no holes in the carpet or the floor! |
| Eric_Shea |
Oct 8 2012, 08:51 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I have an idea from the music industry. Strap lock. Hard to describe but it would work perfectly with our existing floor posts. I'll try to get a picture.
| pnewman |
Oct 8 2012, 09:42 PM
I have an idea from the music industry. Strap lock. Hard to describe but it would work perfectly with our existing floor posts. I'll try to get a picture. Eric, That would be a very nice finish and they are available in a multitude of finishes at that. Black Chrome would work. It would seem that they would have to be installed through the floor for my specific application however. Found some pics. Let me know if this is what you were referring to. Pete Attached thumbnail(s) Attached image(s)
| cary |
Oct 8 2012, 10:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Lo-Fi Version | Time is now: 2nd April 2026 - 09:31 PM |
