WTB: early 70-71 steering column, and blinker switch assembly |
r3dplanet |
Sep 14 2012, 02:29 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
I need a very good condition early steering column, shaft, and turn signal assembly. I have a couple of trashed ones that are no good to me. Good condition to me means no slop in the bearings, clean, electrical connector in one piece, etc.
The '72-later years are quite different so just an early one please. Thanks, Marcus |
markb |
Sep 14 2012, 04:58 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I'm not sure if I have one with the shaft, but I'll look tomorrow.
r3dplanet |
Sep 14 2012, 05:34 PM
Actually, the shaft isn't really an issue. It's the bearing slop and blinker switch that I'm most concerned with.
Thanks! |
markb |
Sep 15 2012, 12:13 PM
I have 3, none of which are absolutely perfect, but you could use 3 to make 1.
This first one spins freely, has a little bit of slop, switch feels good, but the wiring is a mess. The next one spins freely, but feels like the bearings may need to be lubed, also a tiny bit of slop, switch is broken, and the wiring needs help. The last one looks the best, but has no center. The switch feels good, and the wiring is nice with a good connector. Since I'm trying to get rid of everything I have, I'm asking $25.00 each, or all 3 for $50.00, + shipping. Paypal is preferred. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:41 PM |
