WTB: Head Temp Sensor |
seventythree |
Sep 15 2012, 04:44 PM
Newbie Group: Members Posts: 13 Joined: 19-January 07 From: Southern California Member No.: 7,466 |
I'm looking to buy a one-year-only CHTS for the 1973 2.0L application.
VW P/N 022 906 041 A Bosch P/N 0280 130 017 I prefer new. Let me know what you have. Thanks PS, I just tore the rubber gromet the fits around the wire and the engine tin. Any lead on where to buy a replacement would be appreciated. |
SLITS |
Sep 15 2012, 05:25 PM
One chance in hell you will find a new one. The 012 will work.
pilothyer |
Sep 15 2012, 08:02 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
One chance in hell you will find a new one. The 012 will work. (IMG:style_emoticons/default/agree.gif) However, you can get the "012" HTS and simply ad a 270 ohm 1/4 or 1/2 watt resistor in series with it..........Just know this, though, The minimum resistance to the "brain will always be 270 ohms regardless of the resistance offered by the original HTS. This "should not present a problem though, as the enrichment circuit looks at anything below 300 ohms to be a fully warmed engine. |
seventythree |
Sep 16 2012, 09:02 AM
One chance in hell you will find a new one. The 012 will work. (IMG:style_emoticons/default/agree.gif) However, you can get the "012" HTS and simply ad a 270 ohm 1/4 or 1/2 watt resistor in series with it..........Just know this, though, The minimum resistance to the "brain will always be 270 ohms regardless of the resistance offered by the original HTS. This "should not present a problem though, as the enrichment circuit looks at anything below 300 ohms to be a fully warmed engine. Thanks for the tip, but I thought the 73 2.0L had the balast resistor from the factory. Can you elaborate? |
914Sixer |
Sep 16 2012, 08:13 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Go to autohausaz.com and look up 74 2.0 914. 012 are listed under fuel injection $12.35. Go to Radio Shack and buy 270 ohm resistor for under $2. Put the ends on the resistor to plug in. Heat shrink resistor to protect it. Not sure if the factory resistor is still available. Porsche's last price was around $55 if you just go to have the factory one. Resistor was always a plug in item.
Lo-Fi Version | Time is now: 1st June 2024 - 04:05 PM |
