Timing a stock 74 1.8FI, Finally solved my problem |
boiledcabbage |
Sep 22 2012, 08:13 PM
Member Group: Members Posts: 50 Joined: 23-May 05 From: Ottawa, Canada Member No.: 4,131 |
After reading the procedure in The bird site, tech tips 700, and Haynes a million times and many many posts here i have finally realized that my fan only has one factory mark, actually a red notch on the back, rear of the fan - the 7.5 BTDC mark and NO TDC marks. I should have been using this but assumed it was TDC and was trying to set the timing to a point 1/2 inch to the left of it, essentially resulting in
A timing of 15BTDC. Lesson learned? keep trying and listen to the gurus on this site - they are terrific. |
SLITS |
Sep 23 2012, 08:59 AM
If you look close, you won't find a groove but the impeller should be stamped with a 0 for TDC.
Lo-Fi Version | Time is now: 9th June 2024 - 11:50 AM |
