good tools for bending brake lines ? |
jimkelly |
Sep 30 2012, 12:55 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
jeff |
Sep 30 2012, 01:14 PM
Member Group: Members Posts: 252 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
Brake Tube Bending Pliers
These tubing pliers allow you to bend brake tubing easily. Special low-profile head design allows you to bend much closer to the tube nut than conventional tubing benders allow. Also useful for holding tubing while cutting or deburring. For 1/4", 3/16" or 4.75mm tubing only. Made in the USA. Beware of cheap knock-offs! We have been selling these high-quality pliers for years without a single reported problem. By contrast, the foreign-made imitations are made of a weaker metal with a low-quality rivet in the joint. We have one customer who reports that the pair he bought from us has outlasted three of the cheaper version! Qty Part No. Price Stock Status 3158-300 $62.99 In Stock Related products: Brake System Tools https://www.pegasusautoracing.com/home.asp Plumbing Tools |
Nürburg Nomad |
Sep 30 2012, 03:21 PM
914Rubber.com! Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest |
Brake Tube Bending Pliers These tubing pliers allow you to bend brake tubing easily. Special low-profile head design allows you to bend much closer to the tube nut than conventional tubing benders allow. Also useful for holding tubing while cutting or deburring. For 1/4", 3/16" or 4.75mm tubing only. Made in the USA. Beware of cheap knock-offs! We have been selling these high-quality pliers for years without a single reported problem. By contrast, the foreign-made imitations are made of a weaker metal with a low-quality rivet in the joint. We have one customer who reports that the pair he bought from us has outlasted three of the cheaper version! Qty Part No. Price Stock Status 3158-300 $62.99 In Stock Related products: Brake System Tools https://www.pegasusautoracing.com/home.asp Plumbing Tools (IMG:style_emoticons/default/agree.gif) The only tool for bending brake lines! |
VaccaRabite |
Sep 30 2012, 03:26 PM
En Garde! Group: Admin Posts: 13,466 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've used an inexpensive brake line bender from AutoZone on 3 cars now. Unless you need to make more then 180 bends I don't see why you would need more. Has channels in it for 5/16 - 3/8 line.
Zach |
jimkelly |
Sep 30 2012, 03:32 PM
thanks guys!
https://www.pegasusautoracing.com/productde....asp?RecID=6280 and harbor freight's http://www.harborfreight.com/tube-bending-pliers-95782.html jim |
Lo-Fi Version | Time is now: 17th June 2024 - 12:08 AM |
