wiring question, need your help |
metalmorphosis |
Oct 4 2012, 08:15 PM
Member Group: Members Posts: 90 Joined: 31-July 12 From: winston-salem nc Member No.: 14,743 Region Association: South East States |
I was putting the wiring back on my motor last night, which was removed 1 1/2 to 2 yrs ago, and I hit a snag. And just so y'all know its a 73 1.7. The wire in the first pic branches off w the wires that go to the dist and the cold enrichment injector. I had it labeled head sensor, the problem is I labeled the wire in the 2nd pic head sensor. The wire in the second pic comes out of the harness by itself and is closer to the sensor so I assume thats the 1 for the sensor. So where does the wire in the first pic go? Thanks in advance for any help.
Attached thumbnail(s) |
dlee6204 |
Oct 4 2012, 08:23 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Does it go to the thermo-time switch mounted under the plenum?
metalmorphosis |
Oct 4 2012, 08:28 PM
Ah yes! That has to be where it goes. I guess its easy to not even see that one when its buried under everything. Thanks Doug!
dlee6204 |
Oct 4 2012, 08:32 PM
Lo-Fi Version | Time is now: 13th June 2024 - 04:17 AM |
