Oil Circulation/ stock 914 6 |
xsurfer |
Oct 7 2012, 08:46 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I noticed a substantial difference in the oil color when removing the engine. Some was "like new" from the engine, the tank oil was black. Can anyone explain the difference?
Thanks |
Mike Bellis |
Oct 7 2012, 09:15 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm no expert but I would say you have a circulation problem. Maybe all the crap just lingers in the oil tank?
jcd914 |
Oct 7 2012, 11:30 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Don't know why you have a difference and I won't claim to be an expert either.
Roughly the oil circulation on stock 914-6 is as follows: From the bottom of the tank into the suction side of the pressure pump. From the pressure pump thru engine case to the engine mounted oil thermostat. If hot: from the thermostat to the engine mounted oil cooler and on to the main oil galley and on to bearings & such If cold: from the thermostat to the main oil galley and on to bearings & such From the bearings & such down into the bottom of the engine case where the scavenge side of the oil pump picks up the oil and pumps it back to the oil tank. At the oil tank it goes thru the oil filter before dumping back into the tank where it can head back to the engine. If there is and external oil cooler there is an external thermostat between the exit of the scavenge pump and the oil tank where the oil can be routed to the cooler and back where hot. The oil from the tank goes straight into the engine with out being filtered , so what ever the oil in the tank looks like should be what the oil in the engine looks like. If this is a car that has been sitting for a long period of time, maybe the oil in the tank got contaminated. Jim |
DEC |
Oct 8 2012, 12:28 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
xsurfer |
Oct 8 2012, 09:09 AM
Thanks Jim.
I puzzled, the circulation system keep the oil equal. The car has sat for a couple of years due to health issues. The last drive I developed an oil leak from return tubes causing 3 qts. of oil to be added. Gene Don't know why you have a difference and I won't claim to be an expert either. Roughly the oil circulation on stock 914-6 is as follows: From the bottom of the tank into the suction side of the pressure pump. From the pressure pump thru engine case to the engine mounted oil thermostat. If hot: from the thermostat to the engine mounted oil cooler and on to the main oil galley and on to bearings & such If cold: from the thermostat to the main oil galley and on to bearings & such From the bearings & such down into the bottom of the engine case where the scavenge side of the oil pump picks up the oil and pumps it back to the oil tank. At the oil tank it goes thru the oil filter before dumping back into the tank where it can head back to the engine. If there is and external oil cooler there is an external thermostat between the exit of the scavenge pump and the oil tank where the oil can be routed to the cooler and back where hot. The oil from the tank goes straight into the engine with out being filtered , so what ever the oil in the tank looks like should be what the oil in the engine looks like. If this is a car that has been sitting for a long period of time, maybe the oil in the tank got contaminated. Jim |
patssle |
Oct 8 2012, 07:49 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Where is that drawing from?
Michael N |
Oct 8 2012, 08:43 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
When I bought my car I took a ride with Willem Modderman to give me the run down on my car. He told me to make sure that you always listen for the bubble coming from the oil tank and you will know that all is working right (circulation). You can hear the oil percolate in the tank when the car gets warm. I am often asked what the hell is that bubbling when people ride in my car. Bubble Bubble Bubble. Do you get the bubbling on your car?
Lo-Fi Version | Time is now: 2nd June 2024 - 09:51 PM |
