> Master Cylinder Brake Warning Reset Button?
kbrunk1
post Oct 8 2012, 10:11 PM
Brunk
Finally bled my brakes correctly but the light still flashes on the top of the tank level.
Anyone know how to reset the brake warning light?
Replies(1 - 6)
WFG
post Oct 8 2012, 10:19 PM
Reset button on master cylinder if it does not have one try unpluging the wire at master cylinder and plug it back in then check parking brake switch.
William
FlatSix
post Oct 9 2012, 02:42 AM
English Member
I was just going to start a new thread when I saw this. Seems I'm not the only one having issues here!
I've just installed an ate 19mm master cylinder. However there doesn't seem to be a way to reset it. I've pulled off the little black rubber protection sleeve to reveal this. It seems to be one piece of white molded plastic, not a switch. Any ideas?
kbrunk1
post Oct 9 2012, 04:36 PM
Brunk
Pull the emergency brake and release it and clip your seat belts.
it is magic!
Dave_Darling
post Oct 9 2012, 09:07 PM
914 Idiot
QUOTE(FlatSix @ Oct 9 2012, 01:42 AM) *
The middle of that white plastic piece is a button sticking out. Press the button.
And yes, make sure the hand-brake is released.
--DD
FlatSix
post Oct 11 2012, 10:18 AM
English Member
Well I guess it's pressed. It didn't seem much of a switch to me...
I still get a buzzing - relay rapidly clicking - when the handbrake is applied. This goes to the normal speed of clicking when indicators or hazzard flashers are in operation. Is this related to the new master cylinder? It is the only thing that's changed so I'm thinking there might be a connection.
Valy
post Oct 11 2012, 11:18 AM
QUOTE(FlatSix @ Oct 11 2012, 09:18 AM) *
The warning should be on when the handbrake is applied as well as when there is low pressure in the braking system.
Same indication for 2 different reasons. That's the way it's designed.
- Lo-Fi Version Time is now: 9th July 2025 - 10:18 AM
