| 914ltd |
Oct 19 2012, 07:08 AM
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
I try to post this every year at "heating season" I've only seen this type of damage on SSI heats, never the stock systems.
Most everyone knows carbon monoxide is extremely dangerous. It will eventually kill but probably more dangerous to us, it can impair driving skills similar to drunk driving. A home CO detector riding with you with the heat on should be sufficient but there are other devises (as small airplanes) that are better solutions. In the past several 'teeners have posted good information on this subject. Please, try to inform everyone about this potential danger. Brad Attached image(s)
| walterolin |
Oct 19 2012, 07:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Thanks for the post Brad.
CO poisoning is one of my (many) areas of paranoia. Never occurred to me to keep a detector in the car becaused of the HE's. I do have a detector in our house. For those who think they can smell the CO, it is a clear odorless gas. Olin |
| 914itis |
Oct 19 2012, 07:28 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Thanks Brad, for this priceless info.
From my understanding the SSI was not stock? How do you identify SSI vs stock systems ? |
| rnellums |
Oct 19 2012, 07:38 AM
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
| 914itis |
Oct 19 2012, 07:41 AM
You learn something new everyday , I was always under the impression that the SSI 's were stock ..
| Bartlett 914 |
Oct 19 2012, 08:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Thanks Brad, for this priceless info. From my understanding the SSI was not stock? How do you identify SSI vs stock systems ? SSI will be metallic and not rusted(stainless steel). Stock was painted IIRC, but would likely have surface rust all over it now. Not all stainless steel is rust proof. Different alloys can still and do rust. It took years of heat cycles to cause these to rust as they have done. I believe SSI used a different alloy in later years that are not prone to this damage. Problem is you don't know what you have. Better safe and check for leaks. All in all, SSI is a super product. |
| GeorgeRud |
Oct 19 2012, 08:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Thanks for posting these very scary pictures. It shows that even the best products do have a lifespan. General aviation sites have CO detectors available, as do RV stores.
My solution is to drive with the top off all the time! |
| Black22 |
Oct 19 2012, 09:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
You can get a CO detector the size of a pack of cigarettes for $20 at Home Depot. Runs on a single 9v. I installed one under my dash...out of site, but not out of mind.
http://m.homedepot.com/p/Kidde-Carbon-Mono...8905/202756110/ |
| Krieger |
Oct 19 2012, 09:05 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
This may not be a SSI brand heat exchanger. The header looks to be regular steel. IIRC all SSI units are all stainless steel.
| ConeDodger |
Oct 19 2012, 09:30 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Thanks Brad, for this priceless info. From my understanding the SSI was not stock? How do you identify SSI vs stock systems ? SSI will be metallic and not rusted(stainless steel). Stock was painted IIRC, but would likely have surface rust all over it now. If it can happen to a 914 or anything bolted to it, Brad Mayeur would know... |
| bigkensteele |
Oct 19 2012, 10:24 AM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
You can get a CO detector the size of a pack of cigarettes for $20 at Home Depot. Runs on a single 9v. I installed one under my dash...out of site, but not out of mind. http://m.homedepot.com/p/Kidde-Carbon-Mono...8905/202756110/ This is the one that I bought and posted last year. I like that it shows the PPM. Mine has gone off a couple of times and made it up to 20 PPM. I don't think that my exchangers are leaking, as I know that I have an exhaust leak at the heads that I need to fix. http://m.homedepot.com/p/Kidde-Carbon-Mono...8042/100311681/ |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:35 PM |
