Ljet wiring loom rebuild |
davesprinkle |
Oct 24 2012, 08:46 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Like mechanical work, the right tools are important. I use an Xcelite cutter and an Ideal stripper. The crimper is by AMP, intended for Mate-N-Lok connectors, but works well for the Jr Timer contacts in the Ljet loom. I also use a Steinel heatgun. Other tools are: dispenser for isopropanol, razor-knife, scissors, Kapton tape dispenser.
Attached thumbnail(s) |
davesprinkle |
Oct 24 2012, 08:49 PM
Here is a shot of the ECU connector, prior to crimping all the terminals. (Note that the leads are wrapped in Kapton tape, keeps them tidy while standing up to the heat applied by the heat gun.)
timothy_nd28 |
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
davesprinkle |
Oct 24 2012, 08:54 PM
Here's a pic of the loom in process. Here I've established the lead routing for a loom junction. I've wrapped the legs in Kapton tape to keep them tidy prior to shrinking down the sleeving. Tubing is Raychem DR-25. Wires are Raychem spec-55: high strand-count, 18awg, radiation cross-linked Tefzel insulation. (Is that good enough for a 914? I think so, it's good enough for F1 cars...)
914itis |
Oct 24 2012, 08:55 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Hey Dave , are you planing on offering this service for l and djet ?
davesprinkle |
Oct 24 2012, 08:56 PM
Another gratuitous shot of a loom junction prior to sleeving.
Black22 |
Oct 24 2012, 08:57 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Black22 |
Oct 24 2012, 08:58 PM
davesprinkle |
Sorry for the blurry pic. Here is a shot of the heat-shrink boot prior to shrinking. The free wires will be guided into one of the open legs. Note that the branches have all been sleeved at this point.
davesprinkle |
Oct 24 2012, 09:00 PM
Another shot of a similar boot, this time with all the legs guided into their appropriate boot opening.
davesprinkle |
Oct 24 2012, 09:03 PM
Here is another boot. This one is a 1-to-4 junction. I used this one at the end of the loom, where the AFM, injector 1, injector 2, and throttle switch leads all exit the loom.
914itis |
Oct 24 2012, 09:06 PM
davesprinkle |
Oct 24 2012, 09:07 PM
Here is a pic of the loom junction when the boot is fully shrunk. Note the epoxy at the boot entries (RT1125), which is designed to glue the boot to the sleeving, leaving an impermeable covering. (In most cases, all the leads would be sleeved. However, in the Ljet loom, we have two legs with single leads: the coil-sense, and the CHT. I decided to leave them unsleeved.)
davesprinkle |
Oct 24 2012, 09:09 PM
A nice touch is to label all the leads.
davesprinkle |
Oct 24 2012, 09:10 PM
A pic of the completed loom, prior to installation.
davesprinkle |
Oct 24 2012, 09:20 PM
Yes, the car does run with the new loom, in case anyone was wondering...
Black22 |
Oct 24 2012, 10:11 PM
That's puurdy!!!! (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/drooley.gif)
How much? |
timothy_nd28 |
Oct 24 2012, 10:20 PM
Would it be any cheaper than $675?
pete000 |
Oct 25 2012, 12:04 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Impressive work... (IMG:style_emoticons/default/smilie_pokal.gif)
FourBlades |
Oct 25 2012, 06:08 AM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Very cool! I need to make a wiring harness for my race car from scratch. Where did you learn how to do all that? John |
Lo-Fi Version | Time is now: 9th June 2024 - 07:01 PM |
