Adjusting Clutch cable, How much play in pedal? |
ChrisReale |
Nov 3 2004, 02:27 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
How much play do you want in the pedal before it engages? Or, how tight is too tight when adjusting the cable? (IMG:style_emoticons/default/smoke.gif)
Andyrew |
Nov 3 2004, 02:31 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I heard about a half inch pull back on the clutch pedal... could be wrong.
McMark |
Nov 3 2004, 03:21 AM
Less than an inch when pulling back/up on the pedal. But adjust it to where you like it. Some people like it on the floor, some people like it up in the air.
smrz914 |
Nov 3 2004, 03:42 AM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
I adjust mine so that it fully engages when the pedal is not depressed. I know this sounds a little obvious. You want it to be engaged fully when up so that the clutch doesn't slip and fully disengages so that you don't grind into reverse. Adjust it where you like in between.
drew365 |
Nov 3 2004, 09:25 AM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
How about at the bottom end? The stop on the pedal board is supposed to keep the cable from stretching but my stop doesn't adjust enough to do that. I try to not push all the way to the stop. Anyone else have this problem?
Lo-Fi Version | Time is now: 1st June 2024 - 11:10 AM |
