Engine stands, Will a "standard" one work |
qa1142 |
Nov 3 2004, 10:04 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Will standard engine stand work or do I need the adapter ring / bench type?
Why won't a IV case bolt up to regular stand? |
Allan |
Nov 4 2004, 08:37 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
The standard engine stand that I have would not bolt right up to the t4 motor due to a clearance issue with the bottom arms. They were too thick to fit onto the case and put a bolt in because of the lip that runs around the case at the flywheel. Plus the arms were too long to adjust properly. I fixed this by attaching a 16 inch piece of angle iron to the bottom arms and then bolting the motor to it. I like it alot better because all of the adapters I have seen only bolt to the top of the motor and seems a little scary holding all the weight of a fully dressed motor. This way I have a four point attachment that spreads the load around. I will try and post a pick later today.
Lo-Fi Version | Time is now: 10th June 2024 - 07:53 AM |
