seat hinge location, new floor pans |
malcolm2 |
Nov 28 2012, 09:35 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I just finished installing the rear half of my floor pans. Is there a trick to getting the seat hinge mount located in exactly the right location?
The tilt mechanism seems to be the critical factor on this. if the teeth are too tight you get no adjustment. If the teeth are not seated enough, maybe loose some support or even have a slip out issue. |
Socalandy |
Nov 28 2012, 11:02 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
here are some measurements from a parts car. you could also install the Adj. tooth and mock it all up with the seat rails.
Attached thumbnail(s) |
Socalandy |
Nov 28 2012, 11:03 AM
this measurement was taken from the rear firewall (IMG:style_emoticons/default/smile.gif)
jimkelly |
Nov 28 2012, 12:00 PM
i would think if you get the comb tacked in - you could use a seat rail as a template for the hinges.
Attached image(s) |
malcolm2 |
Nov 28 2012, 12:38 PM
Thanks for the replies, I will check the measurements. I am using new aftermarket hinge supports, so I will check for accuracy since the size of the support may be different.
I have been mocking it up with the support bolted to the seat frame |
Lo-Fi Version | Time is now: 16th June 2024 - 07:13 PM |
