914-6 upgrade to 2.4 questions |
brp914 |
Nov 6 2004, 10:55 AM
Unregistered |
Hi,
Any experts out there know if I can use 2.7L crank/rods in an original 914-6 case? If so, can I use the original flywheel and clutch? If not, can I use a 915 flywheel/clutch with the existing clutch cable and gearbox (IMG:style_emoticons/default/wacko.gif) thanks |
J P Stein |
Nov 6 2004, 12:04 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Yes, you can but.......
If you haven't bought Bruce Anderson's book, I would recommend you do so. He describes the many permutations of the 6 cylinder motors with their strengths & weaknesses. Research.....repeat 3 times....before you spend any money. I could give more advice, but I'm just another internet wanker (IMG:style_emoticons/default/laugh.gif) |
sixnotfour |
Nov 6 2004, 12:12 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Yes you can, makes a torquey 2.1something, Plus more compression .Your six flywheel will work too, But the timing marks on the flywheel will be off .just time off the front pulley. It never hurts to lay crank in and double check case clearance.I havent had any problems with the ones Ive done. Cost versus end result is one of the best for the money, If the rest of your motor is decent. Jeff
I agree with JP Look before you leap |
J P Stein |
Nov 6 2004, 12:20 PM
Hay, sixnotfour (I like that (IMG:style_emoticons/default/biggrin.gif) ) another NW guy.
Gots any car pics? |
Lo-Fi Version | Time is now: 9th June 2024 - 03:58 PM |
