Can Anyone Cut A Custom Gauge Panel?, A few holes in a piece of wood |
7TPorsh |
Dec 12 2012, 12:42 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I am re-locating my console gauges up into the dash. I bought a nice piece of grained cherry wood that I want to use; it's about 1/4" thick, 6" wide and about 40" long.I have enough wood for maybe 3 or 4 of these if anyone else interested.
If I send you the rectangular cut wood, does anyone here have the means for cutting out the gauge holes? Basically 5 holes to hold 4 52mm gauges and a 60mm clock in a rectangular shaped piece. Will look like this: oh crap...Admin, please move to garage forum. thx |
VaccaRabite |
Dec 12 2012, 02:38 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
For the 52mm gauges you can use a 2 1/8 inch hole saw, cheap from any hardware store and mounts on a drill. I forget the hole saw size for 60mm (2 5/8) but could be harder to find. Or just buy a variable hole saw, which mounts on a drill or drill press.
gms |
Dec 12 2012, 02:40 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
You could just get hole saws for this and it would be simple, you could even use a hand held drill.
Edit: alright Zach you beat me to it |
7TPorsh |
Dec 12 2012, 03:54 PM
I guess I could just use a "big bit" hole saw. Do the rubber rings need the extra space so 2 1/8" is good?
How can I cut the dash metal? Want to join and enlarge the openings for the vent controls and the radio and make one large rectangular hole.. Use drill with a cutting disc? Roto tooL? I'll have to buy all this stuff... Would love to do the whole dash across but don't have the measurements/template/tools. (like dealers did way back) |
ellisor3 |
Dec 12 2012, 04:54 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
TheCabinetmaker |
Dec 12 2012, 05:10 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I just happen to know a guy who can do that for you. Besides three different size hole saws, you'll need a mandrel to hold them. They run around 25 bucks for a good one.
7TPorsh |
Dec 12 2012, 05:14 PM
don't the rubber rings hold them in place?
VaccaRabite |
Dec 12 2012, 06:26 PM
If you get an adjustable hole cutter you can cut any hole exactly the diameter you want. And the tend to be cleaner then hole saws for wood in my experience.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.icscuttingtools.com-1435-1355358365.1.jpg) Again, you just mount it on a hand drill or drill press and go to town. Super easy to use, but they don't work as well on metal as a regular hole saw. Zach |
VaccaRabite |
Dec 12 2012, 06:27 PM
zig-n-zag |
Dec 13 2012, 01:43 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
I would cut that on a router table free hand.
Hole saws may chip or splinter the wood so use tape on the front and backside to reduce the chances of that happening. |
7TPorsh |
Jan 2 2013, 01:07 PM
well I gave it a shot. ^$%#*&^^$ it
Had two nice pieces of wood, cherry and padauk (beautiful red colored wood) 1?4" thick Shaped the outline then went to cut the holes. *%&(! hole saw! Splintered the shit out of the wood...both pieces. I drilled slow, clamped with another piece of wood underneath. Tried like 5 times So after buying a damn hole saw bit and the wood so far for $40 total I am back to square one...oh, except I now have a huge hole in the dash. So back to original post...Can someone cut a plate for me? At this point I am ok with a metal plate like the stock ones if wood is too damn hard. I'll cover it with vinyl; but exotic wood is my first choice. So anyone? Here is the configuration I want: If metal I just need a plate represented by the red outline; if wood, it's the whole piece from the glove compartment to the steering column...I have an outline for this. |
r_towle |
Jan 2 2013, 03:30 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Try this, it works.
Take your hole saw and drill out a 1 foot long piece of 2*4 with the hole saw size you want. Clamp your piece between the top 2*4 with a hole in it, and a blank bottom 2*4 with clamps on both sides of the hole, nice and tight. Now, slowly drill through the finish piece while keeping the whole mess clamped to a table. If that does not work for you, draw out the piece exactly as you want it and go find a cabinet shop, or a woodworking shop....they will do it for a fee. rich |
7TPorsh |
Jan 2 2013, 05:48 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 07:31 PM |
