> Wiring question, Can anyone tell me where this wire goes to
442nd914s
post Dec 15 2012, 06:05 PM
Getting ready to install the engine and cant remember where this wire goes to. It looks like it goes into the hole next to the drivers side heat port.
On a side note: fuel lines. I have original plastic lines coming from the firewall. The bigger one (10mm) is that the feeding line that goes to the filter.
Thanks for ur help
Replies(1 - 6)
Jeffs9146
post Dec 15 2012, 06:41 PM
Ski Bum
It looks like the one that goes from the alt to the back of the starter main + from the battery!
914itis
post Dec 15 2012, 06:57 PM
Yep, same place as the bla k wire .
yep. the derk area on that sheathing will line up with the grommet where it turns under.
Tom
post Dec 15 2012, 07:10 PM
(IMG:style_emoticons/default/agree.gif) and nice looking engine, clean!
I did notice that your fuel line to the fuel pressure regulator looks a little short, may be the camera angle. Yours line looks to be about about 6 inches, mine is closer to 12 inches. Easier to check now than after engine install.
Tom
442nd914s
post Dec 15 2012, 07:51 PM
QUOTE(Tom @ Dec 15 2012, 07:10 PM) *
Tom
Thanks for noticing my clean engine. I just had it rebuilt to a 2056 cc and took the time to clean & paint all the tin, intake manifolds & mic parts. I also had the alternator & starter rebuilt.
I may have to pull on the cable in question cause it seems to be +/- 2" short of the starter bolt. More pictures to come of the engine.
914itis
post Dec 15 2012, 08:17 PM
The cable should reach of routes properly . There should be ahole on the back metal thin to route the cable
- Lo-Fi Version Time is now: 16th April 2026 - 07:36 PM
