| cwpeden |
Dec 26 2012, 01:34 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I'm trying to help a friend solve an idle problem. Idle is low to the point of stalling and backfiring.
Here's what we have tryied so far: Grounds are good Timing is good Dwell is a litlle high Vacuum hoses are good Cyl head temp sensor good Ballast resistor good Points good Cap good rotor good Been through two trobleshooting guides with no results. Need help figuring out a peculiar problem. When I take the vac lines off the dist I get the the usual high revs but they dont go away when the lines are plugged. Could this be a symptom of a bad vac can on the dist? Any thoughts |
| 914itis |
Dec 26 2012, 05:44 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Was timing set with the vac lines plugged? Try to cap the vac lines going to the dizzy and report back.
| cwpeden |
Dec 27 2012, 03:24 AM
Timing set with vac lines off the dist and plugged.
Thing is, everything seems to work fine except for idle. Smells like too much gas. |
| Bleyseng |
Dec 27 2012, 10:48 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
MPS is correct number (037) and tests good with a vac tester at 15hg for 5 min?
| cwpeden |
Dec 27 2012, 03:55 PM
Does MPS affect idle mixture?
If it was bad I would expect a vacuum leak and high idle. Not 700 down to stall....right |
| euro911 |
Dec 27 2012, 04:34 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
There's not much vacuum being drawn above idle, so a leaky MPS shouldn't affect the mixture too much at higher throttle positions.
Have you checked out PBander's site on troubleshooting? |
| 914_teener |
Dec 27 2012, 04:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There's not much vacuum being drawn above idle, so a leaky MPS shouldn't affect the mixture too much at higher throttle positions. Have you checked out PBander's site on troubleshooting? I think what Geoff is saying is that your post doesn't rule it out. Mark....I think vacuum is highest at idle...with due respect... he mentioned at idle. Could be both MPS and distributor.....ask me how I know. I would suggest you rule out the MPS first. |
| euro911 |
Dec 27 2012, 05:36 PM
Does MPS affect idle mixture? I guessed I missed the high idle part, Rob.If it was bad I would expect a vacuum leak and high idle. Not 700 down to stall....right Not discounting a bad MPS, conducting a simple test with a Mighty-Vac will tell. However, a slow leaking MPS still works OK (not as good as a fully solvent one, of course). The lower the idle, the higher the vacuum, so yes, a real bad MPS will affect the idle mixture. |
| Cap'n Krusty |
Dec 27 2012, 06:06 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I'm trying to help a friend solve an idle problem. Idle is low to the point of stalling and backfiring. Here's what we have tryied so far: Grounds are good Timing is good Dwell is a litlle high Vacuum hoses are good Cyl head temp sensor good Ballast resistor good Points good Cap good rotor good Been through two trobleshooting guides with no results. Need help figuring out a peculiar problem. When I take the vac lines off the dist I get the the usual high revs but they dont go away when the lines are plugged. Could this be a symptom of a bad vac can on the dist? Any thoughts Ummm, Yeah. What "ballast resistor"? 914s don't have a ballast resistor. The Cap'n |
| euro911 |
Dec 27 2012, 06:17 PM
Valves adjusted correctly?
Dwell should be somewhere between 44 & 49 degrees (optimally) Idle speed adjustment on ECU (pot wiper or trace corroded)? Idle adjustment on throttle body? |
| cwpeden |
Dec 28 2012, 02:10 AM
I'm trying to help a friend solve an idle problem. Idle is low to the point of stalling and backfiring. Here's what we have tryied so far: Grounds are good Timing is good Dwell is a litlle high Vacuum hoses are good Cyl head temp sensor good Ballast resistor good Points good Cap good rotor good Been through two trobleshooting guides with no results. Need help figuring out a peculiar problem. When I take the vac lines off the dist I get the the usual high revs but they dont go away when the lines are plugged. Could this be a symptom of a bad vac can on the dist? Any thoughts Ummm, Yeah. What "ballast resistor"? 914s don't have a ballast resistor. The Cap'n I meant the inline resistor on the CHT sensor. not sure why I called it a ballast resistor. Must have been thinking of something else. Will check the MPS though and probably need to pull the dist. for a thorough cleaning. and vac can test. I'll bet the ground wire in the dist is loose too. Just to clarify. With everything hooked up the idle is low to the point of stalling and backfiring. When I pull the hoses to set the timing the idle goes up as expected, but dosent return to normal when the hoses are plugged. Should it? thanks for the suggestions. |
| euro911 |
Dec 28 2012, 10:17 AM
Are you sure the two vacuum hoses to the dizzy are going to the correct vacuum ports? (not reversed)?
| 914_teener |
Dec 28 2012, 01:03 PM
Are you sure the two vacuum hoses to the dizzy are going to the correct vacuum ports? (not reversed)? Good point Mark. I had the advance can go bad once and the mech advance plate inside the dizzy in dire need of lube when I first got the car. I would check those out as well. Sounds like the dizzy to me. Make sure everything is working and lubricated in there.....if it is the stock unit. |
| cwpeden |
Dec 29 2012, 06:41 PM
I'm feeling the same myself, about the condition of the dist. Think I'll just pull the good dist out of my car with the pertronix and see what happens.
| cwpeden |
Jan 11 2013, 01:29 AM
Finally had the chance to go to my friends place tonight to work on his car. Brought my good MPS and Dist. with me.
Tested his MPS and it was good, vacuum wise. Swapped mine in anyways and no change. Swapped in my dist. with pertronix and started right up smooth idle at 1100 rpm and settled down abit. I have his dist on my bench and now I get to learn about distributor rebuilding. Cant be that hard.....right? |
| euro911 |
Jan 11 2013, 01:44 AM
If you don't already have a 'MightyVac' get one. They're relatively inexpensive and an invaluable automotive diagnostic tool serving many applications.
Vacuum canisters, MPS', AARs, and hydraulic systems. |
Lo-Fi Version | Time is now: 29th April 2026 - 06:08 PM |
