last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Why do I have so much steam coming from exhaust? Seems like every time I start it I get lots of water and steam from exhaust. Is this just a function of cold damp weather?
jdlmodelt |
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region ![]() |
Why do I have so much steam coming from exhaust? Seems like every time I start it I get lots of water and steam from exhaust. Is this just a function of cold damp weather? Are you driving a 914 with an air cooled engine in it? IF so, your engine is doing what it is supposed to do. makes water. It will be steaming when you first start it. After the engine warms up the steam is boiling off before you can see it coming out of the tail pipe. That's my take on it. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Moist air condenses (becomes water) in the your exhuast system when it gets cold. When you start it up, it gets hot and the water comes out both as liquid and steam.
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
Or it could be from your radiator. (IMG:style_emoticons/default/confused24.gif)
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,917 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Or it could be from your radiator. (IMG:style_emoticons/default/confused24.gif) Go to your room (IMG:style_emoticons/default/slap.gif) |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
You should sell that steam powered 914 to Jay Leno for big $$$... (IMG:style_emoticons/default/biggrin.gif)
last337 |
Haha thanks for all the replies. I figured it was normal but I dont understand why there would be more steam from air-cooled engine than water cooled (IMG:style_emoticons/default/confused24.gif)
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,408 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States ![]() |
Haha thanks for all the replies. I figured it was normal but I dont understand why there would be more steam from air-cooled engine than water cooled (IMG:style_emoticons/default/confused24.gif) One of the byproducts of combustion is water Combustion of Fossil Fuels: The combustion of all fossil fuels follows a very similar reaction: Fuel (any hydrocarbon source) plus oxygen yields carbon dioxide and water and energy. The simple combustion reaction below is given for methane. Gasoline is more complex; however, the results are basically the same. The combustion of methane means that it is possible to burn it. Chemically, this combustion process consists of a reaction between methane and oxygen in the air. When this reaction takes place, the result is carbon dioxide (CO2), water (H2O), and a great deal of energy. The following reaction represents the combustion of methane: CH4[g] + 2 O2[g] -> CO2[g] + 2 H2O[g] + energy One molecule of methane, (the [g] referred to above means it is gaseous form), combined with two oxygen molecules, react to form a carbon dioxide molecule, and two water molecules usually given off as steam or water vapor during the reaction and energy. |
914itis |
Or it could be from your radiator. (IMG:style_emoticons/default/confused24.gif) Go to your room (IMG:style_emoticons/default/slap.gif)Did I say something wrong? |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Yes, and this is a good reason why you should not drive your car for short little trips. You want your exhaust good and hot when you shut it off to reduce the amount of water in it while sitting.
All cars do this, sometimes I'll see the water pour out of a muffler on a recently started car as they take off from a stop light. |
last337 |
Yes, and this is a good reason why you should not drive your car for short little trips. You want your exhaust good and hot when you shut it off to reduce the amount of water in it while sitting. All cars do this, sometimes I'll see the water pour out of a muffler on a recently started car as they take off from a stop light. I follow what you are saying and understand how water would accumulate in the exhaust. However, the comment was made that implied that being an air-cooled engine would cause more steam and I am still unsure about how that could be the case. |
billh1963 |
I follow what you are saying and understand how water would accumulate in the exhaust. However, the comment was made that implied that being an air-cooled engine would cause more steam and I am still unsure about how that could be the case. I just re-read all the threads and no one said there would be more steam from an air cooled engine vs. a water cooled engine. Where do you see that? (IMG:style_emoticons/default/confused24.gif) |
last337 |
Why do I have so much steam coming from exhaust? Seems like every time I start it I get lots of water and steam from exhaust. Is this just a function of cold damp weather? Are you driving a 914 with an air cooled engine in it? IF so, your engine is doing what it is supposed to do. makes water. It will be steaming when you first start it. After the engine warms up the steam is boiling off before you can see it coming out of the tail pipe. That's my take on it. I thought that was what he was implying with this statement about air-cooled engine and was curious if I was missing something. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,805 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Probably your water pump seal. Or head gasket. Check your heater core. Check your hoses.
Call Auto Atlanta. George will sell you everything you'll need to fix it right up. (IMG:style_emoticons/default/bye1.gif) |
last337 |
Probably your water pump seal. Or head gasket. Check your heater core. Check your hoses. Call Auto Atlanta. George will sell you everything you'll need to fix it right up. (IMG:style_emoticons/default/bye1.gif) Haha, okay thanks! I should probably check that water pump out (IMG:style_emoticons/default/biggrin.gif) |
Nine_14 |
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany ![]() |
I follow what you are saying and understand how water would accumulate in the exhaust. However, the comment was made that implied that being an air-cooled engine would cause more steam and I am still unsure about how that could be the case. I just re-read all the threads and no one said there would be more steam from an air cooled engine vs. a water cooled engine. Where do you see that? (IMG:style_emoticons/default/confused24.gif) Bill, you will become a good teacher..... Open a course .... first steps im physics and chemistry....take money for that. Your first customer is known. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 126,527 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Yes, and this is a good reason why you should not drive your car for short little trips. You want your exhaust good and hot when you shut it off to reduce the amount of water in it while sitting. And your Exhaust will rust from the Inside out. If you car is not Concours, you can drill a small hole at the low point of your Muffler & the water will drain out |
euro911 |
Hmmm .... install a bleeder valve like the one in the bottom of an air compressor (IMG:style_emoticons/default/idea.gif)
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,063 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Check the Fetzer valve on the bypass line... (Name the classic movie)...
Chris H. |
Lo-Fi Version | Time is now: 31st July 2025 - 02:38 AM |
