Rear Brake Calipers, How do I get the Piston out? |
Mike's2nd914 |
May 16 2003, 05:26 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
OK-I have the rear calipers off the car, I have them separated, and I am trying to rebuild the damn things. How in the hell do I get the piston's out? I have tried air, I have tried pliers, I am running out of ideas. The one I am working on was frozen (hence the rebuild). I can get the piston to move about 1/8 inch by beating it back in with a 3# shop hammer then prying back the e-brake lever in my vise. That is all the movement I can get out of it. Any ideas?
Lawrence |
May 16 2003, 05:33 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
You should be able to remove them, one at a time, by using the adjustment screws. Use a 4mm (4.5mm?) allen wrench to back them out.
-Rusty |
Mike's2nd914 |
May 16 2003, 07:59 PM
Thanks, I'll give it a try!
Lo-Fi Version | Time is now: 2nd June 2024 - 03:43 PM |
