sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
inches, mm and spring rate if I knew it at thje time
Attached thumbnail(s) ![]() ![]() ![]() |
sean_v8_914 |
fcyt
sean_v8_914 |
v bn
Attached thumbnail(s) ![]() ![]() |
sean_v8_914 |
hyper coil is 2.5 inch x 10 inch 175# linear
10.1mm or 0.397 inch |
sean_v8_914 |
i also like the 8 inch one with a 2 inch 50# helper with the coleman hats. this keeps it in contact with the seats while the weltmeister stiff short lowering springs tend to unseat when you jack up the car.
2.5 threaded perch set up also unseats coleman hats are deeper and have holes to tie the spring |
sean_v8_914 |
oops: ground control is deeper. coleman has the holes
Lo-Fi Version | Time is now: 8th July 2025 - 09:38 PM |
