installed ER Control Arm Mounts today, very tight fit... |
siverson |
Feb 17 2013, 10:02 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Hi,
I started installing these today: http://www.elephantracing.com/suspension/m...frontmounts.htm and while I'm not done yet, when I installed the rear set (in the cross bar) they were VERY tight to get in there. Is that right? I see how the instructions say not to torque the bolt to the car until the a-arm is in and all is aligned, and I haven't done that yet, but even just getting the mounts in there (no a-arm) was quite tight. Is that normal? -Steve |
siverson |
Feb 17 2013, 10:05 PM
Photo... On both sides, the shiny gold part is super tight going into the aluminum cross member.
Attached thumbnail(s) |
siverson |
And by "super tight" I mean I needed a hammer. Hammers are good, right? (IMG:style_emoticons/default/smile.gif)
-Steve |
bfrymire |
Feb 18 2013, 01:49 AM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
And by "super tight" I mean I needed a hammer. Hammers are good, right? (IMG:style_emoticons/default/smile.gif) -Steve Do a search. I had the same problem with mine. Is that the 911 front crossmember? -- brett |
siverson |
Feb 18 2013, 09:20 AM
Ah, hadn't seen this:
http://www.914world.com/bbs2/index.php?sho...trol+Arm+Mounts That's somewhat helpful. I guess it's often tight. Although your cross member looks bent a little so you couldn't fit any washers in there. Mine are in there, just very tight. I think I will pull them out and grease between them so they can rotate a little easier... > Is that the 911 front crossmember? Yes. -Steve |
Lo-Fi Version | Time is now: 9th June 2024 - 01:22 AM |
