pertronix, did I Kill It |
sanman |
Nov 15 2004, 10:00 AM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
I had the key off and adjusted the gap with everything still pluged in. Is it posible to short the pertronix out with a feeler gauge. found a set of points and the car started.I there a way to test the unite and how.
Jake Raby |
Nov 15 2004, 10:12 AM
Hmmn, are you sure you had the polarity correct??
all it takes is 1/10th of a second to fry it as soon as you turn the key on... |
sanman |
Nov 15 2004, 10:17 AM
It ran before i pop the cap off but in my neverending quest for perfection I just had to check it. never changed anything else wires were the same
Joe Bob |
Nov 15 2004, 10:21 AM
More than likely it's toast...it either works or it doesn't....check and see if you are inside your warranty.
Root_Werks |
Nov 15 2004, 10:27 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Doesn't sound like you had the wires hooked up backwards if it ran before. Maybe the gap is too large? They won't work if the gap is set too large. (IMG:style_emoticons/default/wink.gif)
I don't recall any way of testing just the unit. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:12 AM |
