Wiper switch, Were they all located on the column |
Rhodes71/914 |
Nov 15 2004, 08:16 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I was over at my neighbors 914 bone yard getting some parts. While in one of the cars I was checking out the steering column 'cause my turn signal switch doesn't work and noticed that there is a wiper/washer handle on the opposite side of the column. Mine doesn't have this, I have a button on the dash that operates the wipers and no idea how the washer is activated. Is this something that was changed, my neighbor says that is the case.
Eric_Shea |
Nov 15 2004, 08:19 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yup... changed in 72-73 or something like that. Someone here can give you the real answer but yes, they went on the column.
ejm |
Nov 15 2004, 08:23 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Four cyl. cars thru '71 had the wiper switch on the dash, all sixes and '72 on had column switches. Your washer should work by pushing in the center of the switch.
redshift |
Nov 15 2004, 08:24 PM
I think that was a production change with the early '72 cars, along with all the other interior appointments.. pass seat adjust... ect..
So, 72.5s up... M |
Rhodes71/914 |
Nov 15 2004, 08:54 PM
Thanks guys, can I use the turn signal switch from the newer one on my '71?
markb |
Nov 15 2004, 09:11 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
IIRC, the later switches run their wires thru a connecter. You should be able to just take them out of the connecter and splice them into your wiring.
Lo-Fi Version | Time is now: 4th June 2024 - 03:24 PM |
