Driver Door Storage Compartment, I need verification |
Kaduku |
Mar 6 2013, 08:29 PM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Okay I heard that the driver side door storage compartment thingy (sorry, I don't know what it's officially called) had some sort of a spring. I am assuming the top latch had a spring mechanism that would snap it back down.
Can someone verify this for me and maybe even provide a pic if it's true. I don't see a spring in mine and the top cover just flops down when I let go of it. Sorry for the stupid question (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Mar 6 2013, 08:35 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
yes, it has a spring.
Its located on the inner part of the door/top/flap at the rear. Look at the bottom of the door and you should see a hole for it. I believe it attaches to the screw on the lower side rich |
somd914 |
Mar 6 2013, 09:26 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
yes, it has a spring. Its located on the inner part of the door/top/flap at the rear. Look at the bottom of the door and you should see a hole for it. I believe it attaches to the screw on the lower side rich Not a great pic, but the spring attaches in the slot, enters the black tube (approx 2 inches long) then enters the door panel. |
Kaduku |
Mar 6 2013, 09:44 PM
Awesome, thanks for the pic. I will look at it again. Maybe the spring fell in.
zonedoubt |
Mar 7 2013, 01:44 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The door card has a hole with a metal grommet to keep the spring from tearing through the cardboard.
Lo-Fi Version | Time is now: 31st May 2024 - 05:16 AM |
