| Harpo |
Mar 19 2013, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have a set of 6x16 for the front and 7x16 for the rear. Because of the different widths the same tire will be .8 inch different front to rear. Does anyone have any experience with this?
The tires that I want to buy are the Yokohama s drive and in the 205 tire size They have both 50 & 55 aspect ratios. Some advise would be appreciated Thanks David |
| edwin |
Mar 19 2013, 06:06 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I run a set of boxster 16" same widths with 205/55 and they are really tight but do fit. The rears are rolled a bit to help and needed spacers front and rear to be happy with the fit
What rims do you have? |
| SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
http://www.914world.com/specs/tirecalc.php
You'll need Java installed in your browser ... (IMG:style_emoticons/default/popcorn[1].gif) |
| JamesM |
Mar 19 2013, 06:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Why stagger the rim width if you are not going to do the same with the tire width? Seems like it might look a little funny with the tires fitting differently front to rear. I say get the same size wheel all around or run 205 front/ 225 rear.
| Harpo |
Thanks SirAndy,
I followed the link but the tire calculator does not work. The other options work though. I have Fuchs that these tires are going on. David |
| ChrisFoley |
Mar 19 2013, 06:51 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
205/55 and 225/50 both are the same height (diameter) and are only a little smaller than the original tires.
If you're looking for low profile, the 215/40 and 195/45 are nearly the same height. To me that makes more sense than putting the same size tire on two different rim widths. |
| Harpo |
Mar 20 2013, 04:53 PM
Tire rack recomends the following
205/50R16 for the 6x16 rim (Front) 205/45R16 for the 7x16 rim (rear) The 225 just seems to be too big for the rear. Thanks DAvid |
| ChrisFoley |
Mar 20 2013, 05:37 PM
If you have stock fenders forget about 225s. Even 215s would probably require pulling the fenders a little bit.
IMO it would be smarter to use the exact same tire rather than a lower aspect tire in the rear. If I was doing that I would use the same width rim. Not saying you shouldn't do it, just that I would look for two 6s or 7s to make a matched set. |
| Harpo |
Mar 20 2013, 06:19 PM
Thanks Chris
I value your input so I will go check Pellican for two 6 inch wide rims. I do have stock fenders and was planning on rolling them to make them fit. David |
Lo-Fi Version | Time is now: 4th June 2026 - 01:49 AM |
