> Dual Carb Installation, Success - She Screams
Mblizzard
post Apr 5 2013, 07:36 PM
Working through the less than stellar instructions for the installation of my dual Webers. Beside having obvious errors in them it is not entirely clear which direction the cross bar should be pointed. To the front or the rear. I have not started placing the carbs on the car yet so the moment I move from the bench it may become clear but I think the front is correct. The directions seem to indicate that but if you install the linkage as shown one side of the crossbar link to the carb ends up at the front and the other at the back?
5 Pages V  1 2 3 > »
Replies(1 - 19)
Bob L.
post Apr 5 2013, 07:48 PM
Once installed on the engine the carbs will be staggered a little bit, front to rear. Could that account for what you're seeing?
Pic's are always helpful.
ConeDodger
post Apr 5 2013, 08:03 PM
Apex killer!
The crossbar linkage should be installed in the nearest garbage can.
Call McMark for some good linkage... (IMG:style_emoticons/default/laugh.gif)
Mblizzard
post Apr 5 2013, 08:05 PM
May not be apparent but if you do the bench install as indicated, the connection on the throttle plate for the cross bar link winds up on the wrong side. Meaning the cross bar is to the rear and the connection point is in the front. Attached Image
r_towle
post Apr 5 2013, 08:06 PM
Custom Member
Towards the rear of the car.
jmill
post Apr 5 2013, 08:20 PM
Green Hornet
QUOTE(r_towle @ Apr 5 2013, 09:06 PM) *
But what really matters is what direction the throttle cable pulls. Most have it pull from the front and have the bar to the rear.
On a side note - that setup is one of the poorest ones. Get cast baseplates and the hex bar if you go with the crossbar. If your bar is round throw it in the trash. The arms will slip and it'll flex. You'll be constantly tweaking to get it right. BTDT.
Mblizzard
post Apr 5 2013, 08:24 PM
I will be pulling from the front so looks like a flip is in the works.
Mblizzard
post Apr 6 2013, 05:54 AM
So if I "Call McMark for some good linkage" where do I call and what is good linkage?
r_towle
post Apr 6 2013, 06:02 AM
Custom Member
Original customs in Napa ca, or nearby.
Mcmark here.
He has a center pivot bell crank linkage that may work better.
For the ultimate setup, call Chris Foley at tangerine racing about his cable driven pulley system.
I have tried every cross bar setup I can find, and three bell crank setup.
The cable driven pulley system is just so simple ans so right.
All other systems can and do get out of adjustment over the full curve of the motor running up and down the rpm range.
Cable system is the closest to perfectly matching...
Rich
rhodyguy
post Apr 6 2013, 06:24 AM
mike, i prefer the bar on the front. space is tight enough as it is. with it on the rear, dealing the drop link adjs, and access to the throttle stop screws you be working a little blind and all bent over leaning. imho. plus you'll be making the throttle cable working distance that much longer. did a cable holder come with the package? personally i'd go with the cbtall intakes, not the shortys. if you don't have the cb weber book GET ONE! save yourself a bunch of bs and do the pre-install proceedure. it's clearly written to the point even a caveman can do it. buy the synco tool as well you're going to need one. did you purchase 40s or 44s? while you have them in hand confirm the current jetting. idle, and the components in the main stack. again, easier now than later. be methodical in your approach and don't get frustrated. double check your valve adj NOW! before you fire it up. if the old carb is still on confirm your timing too. not later when your chasing your tail dialing them in. good luck...enjoy the ride.
k
Mblizzard
post Apr 6 2013, 06:57 AM
Kevin - You went through my check list. Timing dead on. Valves already set. New plugs. Completed spread sheet with all jet sizes. Cleaned carbs. Doing complete bench assembly before moving to car. Will disassemble all components and clean again before moving to car.
rhodyguy
post Apr 6 2013, 07:18 AM
as ed china would say. "here's a top tip"...take the engine lid off! you can thank me later for that one. (IMG:style_emoticons/default/wink.gif)
k
ConeDodger
post Apr 6 2013, 07:54 AM
Apex killer!
QUOTE(Mblizzard @ Apr 6 2013, 03:54 AM) *
Mark DeBernardi is McMark here. He owns Original Customs and you may see the banner ad at the top or bottom of the page. The hex bar linkage is a bitch to work with. It is hard to synch and once it is synched will wear and go out of synch fairly soon. I even had one 'arm' break off and had to have my car towed because it was only running on one carb... Mark recommends an imported linkage setup that I have found to be very accurate, easy to synch, and stays tuned... Pic below...
audio_file
post Apr 6 2013, 08:03 AM
QUOTE(r_towle @ Apr 6 2013, 05:02 AM) *
Rich
+1 to this ^ being a great option. I had the hex cross-bar setup and removed it just because I thought it was UGLY (IMG:style_emoticons/default/barf.gif) After installing the tangerine setup, I was blown away by how much more smoothly the carbs/pedal operated. Easy to sync up, no bushings to wear out like the X-Bar too. (And, it looks better (IMG:style_emoticons/default/happy11.gif) )
Chris
vw505
post Apr 6 2013, 02:39 PM
I looked on McMarks web site and didnt see it listed
Mblizzard
post Apr 6 2013, 06:55 PM
Installation looks pretty good. Some set up still to come. Attached Image
Mblizzard
post Apr 7 2013, 07:43 PM
Beaten! Tried everything possible to get these to run. They seem to do fine and run well for a minute or 2 when first starting the car. Engine revved well ans it sounded great. Then it almost seems like a choke or something kicks in and the car will barely idle and the dies. When I could keep it running none of the adjustment procedures seemed to have any impact on the smoothness. I will post some additional details tomorrow. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
ConeDodger
post Apr 7 2013, 07:51 PM
Apex killer!
I repeat: Install in nearest garbage can... (IMG:style_emoticons/default/biggrin.gif)
jmill
post Apr 7 2013, 07:56 PM
Green Hornet
Are they new or did you rebuild them? Also you need to use the thick spacer and good gaskets on the base of your manifolds. Cheap manifolds and thin gaskets give you vacuum leaks and needle valve adjustments have little to no effect.
Mblizzard
post Apr 7 2013, 08:21 PM
I used the ones that came with the new carbs. I have some of the thicker ones but I checked well for vacuum leaks and found none. If I had vacuum leaks it would seem like the idle would be high. But Tim seems like once it gets done running right after starting it just seems to run slower and slower until it backfires and dies. When you first start it it revs great and then just seems to shut down. It will do that every time you restart it.
Recheck everything for 6 hours. Verified fuel pressure. Timing good. Valves set. New fuel filter. I need a drink!
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 9th June 2026 - 01:17 AM
