TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I have a 2056 with raby 9550 cam, and 9:1 compression ratio. I've recently had some problems with pre ignition with a fully warm engine. It usually happens when transitioning from cruise to WOT. I tried retarding the timing to no avail. The engine has been increasingly hard to tune and inconsistent. I could just not get the timing, dwell, and afr to work together at idle.
Whist searching the net for something unrelated, I stumbled on a page at the ngk website. Now, I've always used ngk BP6es plugs with never a problem. the article explained the causes and effects of pre ignition (or detonation). With the info from the article, I deduced that my 6's were too hot, and that my.034 plug gap was too great. This morning I replaced the 6's with 7's and reduced plug gap to 28. The difference upon startup was quite pronounced. The idle smoothed, I was able to obtain 12.7 afr at idle with the ecu knob, and re advance the timing to factory specs. the results were a smoother acceleration with what felt like(butt dyno) increased power in the upper rpms, and no detonation. I'm shocked at the difference a cooler plug made. Hope this helps if your having a similar problem |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) that's what so great about this board, sharing of solutions....
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I have a 2056 with raby 9550 cam, and 9:1 compression ratio. I've recently had some problems with pre ignition with a fully warm engine. It usually happens when transitioning from cruise to WOT. I tried retarding the timing to no avail. The engine has been increasingly hard to tune and inconsistent. I could just not get the timing, dwell, and afr to work together at idle. Whist searching the net for something unrelated, I stumbled on a page at the ngk website. Now, I've always used ngk BP6es plugs with never a problem. the article explained the causes and effects of pre ignition (or detonation). With the info from the article, I deduced that my 6's were too hot, and that my.034 plug gap was too great. This morning I replaced the 6's with 7's and reduced plug gap to 28. The difference upon startup was quite pronounced. The idle smoothed, I was able to obtain 12.7 afr at idle with the ecu knob, and re advance the timing to factory specs. the results were a smoother acceleration with what felt like(butt dyno) increased power in the upper rpms, and no detonation. I'm shocked at the difference a cooler plug made. Hope this helps if your having a similar problem Thanks for the info, since I am building essentially the same engine. I will be stopping by with the 911 week after next. Never been to OK before. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
What octane fuel are you running?
You could have probably kept everything else the same and run slightly higher octane. Stu |
TheCabinetmaker |
I've been using 91, real gas.
stugray |
QUOTE Never been to OK before. Well I spent quite a few years at OU. Just north of Norman & south of OKC on 35 is a huge Pick your part that had dozens of 914s back in ~1990. South of Norman was an airfield sized VW junkyard as well (My 70 Ghia was laid to rest there before buying my first 914) I used to coach & Judge Gymnastics all over Oklahoma in 84-90. Stu |
snakemain |
Ronin Member ![]() ![]() ![]() Group: Members Posts: 582 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None ![]() ![]() |
Oklahoma Foreign. (oklahomaforeign.com) Gets picked over fairly regularly now by the OKC 914 guys. Lived in Edmond, OK, till last year, now outside St Louis.
Lo-Fi Version | Time is now: 21st August 2025 - 05:53 AM |
