> Best Jack Stands
jesiv
post Apr 14 2013, 10:37 PM
I can't seem to find good jack stands at least the top. What do you consider the best jack stands for a 914?
Regards
James
Replies(1 - 7)
euro911
post Apr 15 2013, 12:01 AM
Steve
post Apr 15 2013, 12:11 AM
Make sure there they have a pin in them. The ones with a lever are known to fail.
URY914
post Apr 15 2013, 04:51 AM
The best 914 jackstands are ones that can be removed from under a 914. There are some which once your 914 is put up on them they get stuck almost like welded under your 914. It's like you can't get them out from under there. Strange really...... (IMG:style_emoticons/default/sad.gif)
nathansnathan
post Apr 15 2013, 07:12 AM
These are the best ones I have found. Since the bottom of the car is flat, they work well for for when both ends are off the ground. They are a little weird to use when you are lifting just 1 end though.
http://www.pelicanparts.com/catalog/shopca..._ESCOJS_pg2.htm
r_towle
post Apr 15 2013, 08:14 PM
Custom Member
QUOTE(URY914 @ Apr 15 2013, 06:51 AM) *
Its procrastination organic fusion.
Randal
post Apr 15 2013, 08:51 PM
The best free standing (triangle) ones have a circle welded on the top that just fits around the donuts on the bottom of our cars. Great for CA where we have big earthquakes.
Mark Henry
post Apr 15 2013, 08:55 PM
that's what I do!
Two post lift. (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 14th April 2026 - 11:37 PM
