> Unsprung weight, 914 front hub/rotor and caliper
ww914
post Apr 16 2013, 07:43 AM
914 Convert
Anyone know the weight of a stock 914 front hub/rotor and caliper?
Replies(1 - 4)
McMark
post Apr 16 2013, 11:20 AM
914 Freak!
Rotor with bearings is about 15lbs.
Bare strut (no insert) is about 14lbs.
Caliper is about 7lbs.
Add in misc pieces (dust shield, pads, strut insert, etc) and you're probably up around 50-55lbs not including the A-arm.
ww914
post Apr 17 2013, 08:51 AM
914 Convert
QUOTE(McMark @ Apr 16 2013, 10:20 AM) *
I've been collecting parts to convert to 5 stud. My 911 rotors, Brembo calipers and hubs weight about 20.6 lbs together, so I guess they would be a tad lighter, assuming the struts weigh about the same.
So the advantages I see are:
1 - A little lighter
2 - Bigger brake
3 - Easier to change wheels with studs rather than lug bolts.
What else am I not considering?
blitZ
post Apr 17 2013, 09:00 AM
Beer please...
I used Eric's aluminum Brembo AM calipers for my 5 lug. It's about 2.25 lbs lighter than a stock 914 caliper.
jcd914
post Apr 17 2013, 09:49 AM
QUOTE(ww914 @ Apr 17 2013, 07:51 AM) *
2 - Bigger brake
Better choice of wheels?
You maybe going from pinch bolt struts to wedge pin struts, which is an improvement.
The wheel bearing are a bit bigger.
Jim
- Lo-Fi Version Time is now: 31st July 2025 - 12:06 AM
