LED Update |
LED Update |
Qarl |
Nov 23 2004, 09:25 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Bulbs should be shipping to me on Friday (factory had problems with supplies).
I DID ship today to those that previously ordered LED bulbs, the resistor packs to solve the turn signal indicator issue. It's a simple plug and play adapter. You simply connect one end to the bulb housing lead and the other end to ground (such as the ground lug on the back of the gauges). Then you just make your normal connections using the second (piggyback) connector built into the resistor pack. If you order from this point forward, they are going to cost you, as they are a big pain to make. Cost is $2.99 for the resistor pack. If you are on back order, I got you covered. Details are on my website. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 04:28 AM |
