Throttle body, 75 1.8L |
57lincolnman |
May 4 2013, 11:29 AM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
My throttle body on 75 1.8L will not return to idle when revved. It will return to lower RPM @ 1200 or so. Can these be rebuilt? I think there is play in the shaft which causes the valve inside to stick. I think this is a very common problem for 1.8's so finding a used one may not be best option. Would like to know how others have solved this. Thanks
dlee6204 |
May 4 2013, 11:33 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I simply fixed mine by taking apart and cleaning it. I also tweaked the return spring for slightly more tension.
Drums66 |
May 4 2013, 12:22 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Maybe just spring tension? (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Dave_Darling |
May 4 2013, 08:33 PM
They can have bushings installed. I don't know offhand of anyone who does that, but any decent machinist should be able to.
--DD |
Lo-Fi Version | Time is now: 8th June 2024 - 12:20 AM |
