| Mblizzard |
May 7 2013, 07:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok seems simple. Voltage light on dash on. Battery dies. Replaced voltage regulator with a wells VR650. Light on dash off. All seems good. But voltmeter shows the voltage dropping the longer the car runs until it dies. Voltage does not change regardless of engine speed.
Put the old regulator back on. Light on dash stays on regardless of engine speed. But voltmeter shows an increase in voltage with engine speed. I have not gotten the battery charged yet to see if running the engine discharges the battery. I am at a loss as to what try next. |
| r_towle |
May 7 2013, 07:27 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Seriously, tap the VR a few times, it may be stuck.
| bcheney |
May 7 2013, 08:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Seriously, tap the VR a few times, it may be stuck. My six conversion is acting up with alt/reg issues. Has operated with no issues showing close to 14 volts on the gauge under power. Mine is a 2.2 carbed car with webers, MSD, internally regulated alternator and standard point ignition. A few days ago the gauge started reading 12 volts. I put a meter on the battery while its at idle and it says 11.85 volts. I share your pain as I have always been challenged by figuring out electrical problems....Maybe some of The 914World house experts can chime in and help us out... |
| Mblizzard |
May 7 2013, 08:48 PM
| SLITS |
May 8 2013, 06:48 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Seriously, tap the VR a few times, it may be stuck. My six conversion is acting up with alt/reg issues. Has operated with no issues showing close to 14 volts on the gauge under power. Mine is a 2.2 carbed car with webers, MSD, internally regulated alternator and standard point ignition. A few days ago the gauge started reading 12 volts. I put a meter on the battery while its at idle and it says 11.85 volts. I share your pain as I have always been challenged by figuring out electrical problems....Maybe some of The 914World house experts can chime in and help us out... Mine (2.7L) doesn't show correct charge until 2K (approximate) RPM on startup. I have to blip the throttle to get the light to go out. The diode or diodes in the alternator could be bad. The alternator makes AC voltage and is then rectified to DC. The brushes could have gone south (worn out). Pull the alt and have it tested. |
| Mblizzard |
May 8 2013, 07:23 AM
[/quote] Pull the alt and have it tested. [/quote] That is what I was afraid of. Can't I just take a swift kick in the groin? |
| SLITS |
May 8 2013, 07:29 AM
[quote name='Mblizzard' date='May 8 2013, 06:23 AM' post='1861130']
[/quote] Pull the alt and have it tested. [/quote] That is what I was afraid of. Can't I just take a swift kick in the groin? [/quote] No Pain .. No Gain (IMG:style_emoticons/default/av-943.gif) Really ... if you don't show 13.8 VDC at the battery at fast idle with a good VR, the alt is suspect (or corroded terminals / high resistance wiring in the battery cables as in old). |
| Cap'n Krusty |
May 8 2013, 07:50 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Before you go any farther. Check the fuses and their connections. Then buy a genuine Bosch voltage regulator.
The Cap'n |
| bcheney |
May 8 2013, 08:10 AM
| Mblizzard |
May 8 2013, 10:33 AM
Hard to guess against the Captian! But if the light was on with the Wells I would be content in that but there is only one thing to do. Where do I get the Bosch vetsion?
| luskesq |
May 8 2013, 10:44 AM
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Seriously, tap the VR a few times, it may be stuck. My six conversion is acting up with alt/reg issues. Has operated with no issues showing close to 14 volts on the gauge under power. Mine is a 2.2 carbed car with webers, MSD, internally regulated alternator and standard point ignition. A few days ago the gauge started reading 12 volts. I put a meter on the battery while its at idle and it says 11.85 volts. I share your pain as I have always been challenged by figuring out electrical problems....Maybe some of The 914World house experts can chime in and help us out... Mine (2.7L) doesn't show correct charge until 2K (approximate) RPM on startup. I have to blip the throttle to get the light to go out. The diode or diodes in the alternator could be bad. The alternator makes AC voltage and is then rectified to DC. The brushes could have gone south (worn out). Pull the alt and have it tested. Slits, if you have upgraded to an internally regulated alternator, they recommend a 91 ohm resistor added to the alternator light. My light drops out at about 1k rpm. Keith |
| damesandhotrods |
May 8 2013, 11:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
I just replaced my voltage regulator about a month ago. I got a Bosch replacement from Pelican. Life has been better ever since…
| Drums66 |
May 8 2013, 12:00 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....My advice, convert to electronic(VR) (IMG:style_emoticons/default/thumb3d.gif)
I.ve been using Borg warner, with no issue's for yrs (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
| damesandhotrods |
May 8 2013, 12:06 PM
I goofed; it is a Hella not a Bosch. But judging by the size I’m pretty sure the Hella is an electronic voltage regulator. And it’s a plug in replacement…
| Mblizzard |
May 8 2013, 03:34 PM
Did not find a voltage regulator on the bird site. You have a place and prat number for that Hella? I guess that I will just have to replace the alternator! But that kick would still be my preferred option.
Charges the battery. 13 plus volts. Did not have time to see if it was discharging but the car dies when the cable is removed. Will drive it a bit tonight with the lights on to verify the discharge. As a side note, the PO had the voltage meter wired in an odd way. They had the lead from the alternator run to the meter then a return wire to the starter. I replaced that wiring with a factory center console set up. Maybe I will put that meter back in the loop to see what happens. But it should not make any difference but who knows with a 40 year old cars wiring system? |
| SLITS |
May 8 2013, 03:54 PM
Seriously, tap the VR a few times, it may be stuck. My six conversion is acting up with alt/reg issues. Has operated with no issues showing close to 14 volts on the gauge under power. Mine is a 2.2 carbed car with webers, MSD, internally regulated alternator and standard point ignition. A few days ago the gauge started reading 12 volts. I put a meter on the battery while its at idle and it says 11.85 volts. I share your pain as I have always been challenged by figuring out electrical problems....Maybe some of The 914World house experts can chime in and help us out... Mine (2.7L) doesn't show correct charge until 2K (approximate) RPM on startup. I have to blip the throttle to get the light to go out. The diode or diodes in the alternator could be bad. The alternator makes AC voltage and is then rectified to DC. The brushes could have gone south (worn out). Pull the alt and have it tested. Slits, if you have upgraded to an internally regulated alternator, they recommend a 91 ohm resistor added to the alternator light. My light drops out at about 1k rpm. Keith I don't use the internal VR. There was a problem when the engine got hot and being the VR is close to the case, the light would come on from an overheated VR and give the driver a heart attack as he would think he lost his cooling due to a broken belt. Maybe it's a poor excuse but I am known for those. |
| Cap'n Krusty |
May 8 2013, 04:49 PM
914s are not known for losing cooling function when the alternator belt breaks .....
The Cap'n |
| ThePaintedMan |
May 8 2013, 05:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
914s are not known for losing cooling function when the alternator belt breaks ..... The Cap'n (IMG:style_emoticons/default/confused24.gif) |
| mepstein |
May 8 2013, 05:19 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
914s are not known for losing cooling function when the alternator belt breaks ..... The Cap'n (IMG:style_emoticons/default/confused24.gif) George- The fan is affixed to the crank. It spins when the engine turns over. Not like a 911. |
| SLITS |
May 8 2013, 06:24 PM
Ok Experts .... I run a 2.7L six. Wanna repeat the loss of cooling statement?
Lo-Fi Version | Time is now: 2nd April 2026 - 08:35 PM |
