> Car is dead, Confused. Need help
jfort
post May 16 2013, 04:24 PM
Last week I thought I needed a battery. It was low but I could hear the fuel pump, just not enough power to start. I put on charger. I got it to start. Figured I needed a new battery or that there was a draw on the battery. Went to Advance Auto. Analyzer said battery was fine. As a precaution, I bought a good Sears battery maintainer. I was gone until today. Maintainer says battery fully charged. I try to start the car -- absolutely NOTHING. No fuel pump. No nothing. I tried to start with big jump starter I have. No nothing. It doesn't even spark as I connect it as it usually does.
Voltmeter says there is 12.7 across battery terminals. There is 12V at the fuse block.
I am confused. I've seen defective batteries that acted like this. But it is supposedly charged and jump starter has no effect. What am I missing? Help
Replies(1 - 5)
biosurfer1
post May 16 2013, 04:30 PM
Teener fo Life!
relay?
underthetire
post May 16 2013, 05:06 PM
And check the ground strap.
442nd914s
post May 16 2013, 05:09 PM
When you turn the key do any of the component work or light up? I.e. turn signals, headlights, wipers
If so, then I would start at tge ground terminal then cables at the starter. Check for voltage at the starter. Also check for voltage at the coil + with ignition on.
ConeDodger
post May 16 2013, 05:10 PM
Apex killer!
QUOTE(underthetire @ May 16 2013, 03:06 PM) *
+1 you can have all the juice in the world and without proper grounding you will not spin the starter...
jfort
post May 16 2013, 05:16 PM
QUOTE(scotty boy @ May 16 2013, 02:43 PM) *
Check your positive cable there's 4 little red cables that power th various components. They are crimped to the cable where it connects to the battery. Some times they work loose or are oxidized. Try moving the cable clamp around the battery post. You may need to strip back 1/4 inch and recrimp the red cables to get a better connection.
Step two: clean your grounding posts and ground for the negative cable where it connects to the brass post on the inner fender.
Step three check your plastic ignition switch it may have a crack in it.
Thanks, Scotty Boy. It was your step 2. In hooking up the battery maintainer last week, I wired in the negative terminal lug to where the negative battery cable bolts to the inner fender. Your advice made be check that. SURE ENOUGH, no ground from battery to car. YOU'RE THE MAN.
- Lo-Fi Version Time is now: 9th June 2026 - 01:33 AM
