| shuie |
May 18 2013, 08:11 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
These are really cool, but they absolutely will not work with a normal 15" Porsche wheel on a narrow body car.
They are a lot of fun if you are into bending your own brake lines, trying to figure out ways to correct bump steer, and trying to find wheels that will fit the car after they are installed. Too much of a PITA science project for me (IMG:style_emoticons/default/headbang.gif) Stock early Boge struts off of a '71, so they will work with 320i calipers without shaving anything once you get everything else mentioned above sorted out. If anyone wants these I'll swap them for either: -set of the trim pieces that go around the sail panel -a good functioning engine lid with no broken hinges (preferably black) -a decent set of black door panels TIA (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-2075-1368886275.1.jpg) |
| tweet |
May 18 2013, 12:41 PM
Member ![]() ![]() Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
These are really cool, but they absolutely will not work with a normal 15" Porsche wheel on a narrow body car. They are a lot of fun if you are into bending your own brake lines, trying to figure out ways to correct bump steer, and trying to find wheels that will fit the car after they are installed. Too much of a PITA science project for me (IMG:style_emoticons/default/headbang.gif) Stock early Boge struts off of a '71, so they will work with 320i calipers without shaving anything once you get everything else mentioned above sorted out. If anyone wants these I'll swap them for either: -set of the trim pieces that go around the sail panel -a good functioning engine lid with no broken hinges (preferably black) -a decent set of black door panels TIA (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-2075-1368886275.1.jpg) I'll trade. Which part do you want the most? I have all of them available/\. dan |
| shuie |
May 18 2013, 01:36 PM
What if I throw in a bumpsteer solution that came on the car with these struts and a set of adjustable drop links for a front sway bar?
Would that get me a black engine lid w/good hinges and the sail panel trim? (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1368905794.1.jpg) |
Lo-Fi Version | Time is now: 9th June 2026 - 08:17 AM |
