| parrish911 |
May 18 2013, 04:14 PM
Newbie ![]() Group: Members Posts: 35 Joined: 27-April 06 Member No.: 5,939 Region Association: South East States |
I have a '73 2.0 that is primarily used for auto-x with occasional weekend drives. I live in Tampa, FL. There is a copper bellows type thermostat that is used to control a flapper valve that routes cooling air. The bellows expands with heat and gradually opens the flapper valve, directing more air to the cylinders.
My question, is there any downside to bypassing the bellows and leaving the flapper valve in the always open position? I don't really deal with 'cold' weather and I am not convinced there is any benefit to having this on the engine, given how I am using the car. I would welcome your thoughts on this. Thanks, Steve |
| bandjoey |
May 18 2013, 04:23 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I don't think it matters in hot weather. I keep mine open in Texas from March to October. Open in cold weather it just slows down the warmup.
| parrish911 |
May 18 2013, 05:54 PM
Thanks Bill. I was thinking the same thing. Plus, I am a big believer in the simpler I make the car, the less things there are to malfunction.
Steve |
| nathansnathan |
May 19 2013, 02:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
Without the thermostat, the engine will take a long time to warm up. My work is 12 miles away freeway driving. With the flaps open, water in the oil will not burn off. You will see a frothy sludge in your filler cap.
| Bleyseng |
May 19 2013, 07:50 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Leave it in as it speeds warmup as VW/Porsche had a real reason to do this.
| Drums66 |
May 19 2013, 11:48 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
| Rand |
May 19 2013, 11:51 AM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Yes, as said, it means slower warmup. Would you remove the thermostat from every other daily driver that shipped with it from the factory? Is there a reason it's a good idea that every car comes with a thermostat?
I guess I should fix mine some day. (IMG:style_emoticons/default/biggrin.gif) |
| SirAndy |
May 19 2013, 11:54 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Without the thermostat, the engine will take a long time to warm up. My work is 12 miles away freeway driving. With the flaps open, water in the oil will not burn off. You will see a frothy sludge in your filler cap. (IMG:style_emoticons/default/agree.gif) I ran my 2056 without the thermostat here in MidCal and i had the same problem since most of my driving are rather short trips (less than 20 miles). Not enough heat in the engine to boil off the water in the oil and massive sludge buildup on the filler cap and neck. If you stay on top of this and clean off the sludge often (really messy affair) you might be OK. But what do you think is the downside of running the thermostat? (IMG:style_emoticons/default/confused24.gif) It only helps warming up the engine to normal operating temp, after that, the flaps are fully opened anyways. (IMG:style_emoticons/default/popcorn[1].gif) |
| Rand |
May 19 2013, 12:03 PM
But what do you think is the downside of running the thermostat? (IMG:style_emoticons/default/confused24.gif) It only helps warming up the engine to normal operating temp, after that, the flaps are fully opened anyways. (IMG:style_emoticons/default/popcorn[1].gif) I'm curious about a response to this too. Is your thermostat functioning? If so, why would you want to remove it? It's not complicated or heavy. And to answer your specific question, there is absolutely a downside to removing it and I hope you will be convinced there is a benefit to keeping it. |
| parrish911 |
May 19 2013, 03:19 PM
Wow, thanks for all the responses. I will try to answer the questions posed. My concern with the thermostat was @ 40 yrs old it may not be fully functional and is really not needed here in Florida. I did not think about cooking off the water in the oil. I did test the thermostat in water and it does appear to function. I measured a heated length of 46mm @ 155 F (I found this test in the Porsche shop manual).
Dumb question: is this thermostat present in all 914/4 engines? Bill Andrews, have you seen the oil/water sludge with your 914 during Texas summers? Again, I really appreciate all the responses. As everything appears to be functional, I think I will lube everything up (flap hinges & cable pulley) and reattach it. Steve |
| Dave_Darling |
May 19 2013, 04:16 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,342 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The thermostat is present in all 914-4 engines as they were delivered from the factory. A number of people decided that the cooling flaps were not needed, nor was the thermostat.
Removing the cooling flaps, interestingly, tends to lead to hot running. --DD |
| Cap'n Krusty |
May 19 2013, 04:40 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The failure mode of the thermostat would be in the fully open (running) mode. The coil spring on the flap rod holds the flaps where you want them to be, in the default position.
The Cap'n |
| Elliot Cannon |
May 19 2013, 05:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
My thermostat/bellows have been removed since the engine was built by FAT Performance about 25,000 miles ago. It's not a daily driver, takes awhile to warm up but that has never been a concern for me. Having said that, your engine undergoes much more wear prior to operating temperature when cold, than it does when finally at operating temp. The sooner you can get the engine to operating temperature the better.
| mrholland2 |
May 19 2013, 07:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
My engine installing mechanic installed the flaps in the always open mode. I drive 5.63 miles a day each way to work, which takes me about 20 or more minutes. It is nearly time for an oil change and no sludge . . frothy or otherwise.
The concern wasn't the thermostat as much as it was the mechanics of the flapper device/rods/springs going kerflooey and sticking shut. Sean |
| bandjoey |
May 19 2013, 10:13 PM
My daily drive is 30 miles each way. I don't have sludge but probably due to distance driven every time I start the motor
| SirAndy |
May 20 2013, 12:11 AM
The concern wasn't the thermostat as much as it was the mechanics of the flapper device/rods/springs going kerflooey and sticking shut. They can't get stuck closed. Their failure mode is wide open for max. cooling. (IMG:style_emoticons/default/shades.gif) |
| Dave_Darling |
May 20 2013, 04:29 PM
Oh yes, they can get stuck closed! Trust me on this. If the linkage binds up, they can stick in any position, including closed.
--DD |
| SirAndy |
May 20 2013, 05:01 PM
Oh yes, they can get stuck closed! Trust me on this. If the linkage binds up, they can stick in any position, including closed. Have you seen the spring on that thing? One would have to seriously go at the linkage with a BFH (IMG:style_emoticons/default/smash.gif) to get it to bind. (IMG:style_emoticons/default/shades.gif) |
| ww914 |
May 20 2013, 05:17 PM
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
The failure mode of the thermostat would be in the fully open (running) mode. The coil spring on the flap rod holds the flaps where you want them to be, in the default position. The Cap'n Cap'n Are you saying that the default position is holding the flaps wide open? I could be wrong but it seems that the spring holds the flaps closed and the thermostat, when working, opens them up. I have CHT gauges on all 4 cylinders, and with full tension on the wire, the cylinders show much lower temperatures. I wished I would have taken a closer look at it when I had it apart. |
| Dave_Darling |
May 20 2013, 08:51 PM
Have you seen the spring on that thing? One would have to seriously go at the linkage with a BFH (IMG:style_emoticons/default/smash.gif) to get it to bind. (IMG:style_emoticons/default/shades.gif) Yes, I have seen it. And no, it doesn't require a BFH to get it to bind. The spring moves the flaps to the "maximum cooling" position, the thermostat pulls them into the "warm the engine up" position. The failure mode is almost always to go to max cooling. --DD |
Lo-Fi Version | Time is now: 9th June 2026 - 01:01 PM |
