| Michael N |
May 19 2013, 10:01 PM
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
| Michael N |
May 22 2013, 07:07 PM
How about $35.00 shipped.
| ajracer |
May 22 2013, 09:19 PM
Member ![]() ![]() Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Greetings:
So is this solenoid a direct "bolt-in" ? just requires the wiring, or is additional items need to make useable ? Appreciate your reply. Allan |
| Michael N |
May 23 2013, 09:31 AM
It bolts in and needs to be wired. It is used when a car has the aftermarket Porsche reflector added so that the trunk can be opened woth out drilling a hole in the reflector. I do not recommend adding the reflector but if someone already has one installed then this is a good back up solenoid if one fails. With the addition of the reflector the owners also need to add a cable release in case their solenoid ever fails so that the can easily access the trunk.
Lo-Fi Version | Time is now: 9th June 2026 - 01:39 PM |
