> On Topic: Brake MC upgrade question, 20mm MC install
skline
post Nov 27 2004, 10:51 PM
Born to Drive
I got a 20mm Master Cylinder for a 80's SC and was told it will fit on my car. Brad? Any tips on installing this bad boy? Or anyone else out there with any experience in this endeavor?
Replies(1 - 9)
Brad Roberts
post Nov 27 2004, 11:10 PM
914 Freak!
20mm ? Show a pic of it. The only thing I can think of that might be different is the inlet holes might be in a different location.
B
hargray2
post Nov 27 2004, 11:57 PM
fuh-q
Didn't someone recently ask about a M/C with a "20" cast into it that turned out to be a power assist unit?
skline
post Nov 28 2004, 01:55 AM
Born to Drive
Oh great, so it may not work at all? Here is a few pictures of different angles. Let me know what this is and if I can use it.
skline
post Nov 28 2004, 01:56 AM
Born to Drive
Second shot
skline
Born to Drive
Last one
davep
post Nov 28 2004, 08:51 AM
914 Historian
That is for a boosted unit, can't see how it would work.
The only 20mm that normally fits was the one used with the 911 aluminum S calipers. This started with the 69 911S. As soon as they went with power brakes the whole design changed. The original 20mm has been unavailable for a very long time.
ClayPerrine
post Nov 28 2004, 09:23 AM
There is a factory 19mm master cylinder that will bolt on to a 914. It was used on 911s with the S-calipers. There is also a 23mm Mercedes Benz unit that will bolt onto a 914. You have to do some adjusting to the brake lines to get it on the car. If you use it with stock or slightly upgraded brakes, you will get a very hard pedal and no travel. It would be good for very large, multi-piston calipers.
skline
post Nov 28 2004, 10:06 AM
Born to Drive
Well, I have stock rear calipers so I could retain the E brake, I have Volvo 240DL calipers up front which are 4 piston. Currently I have a stock 17mm MC, how do you think it will be like it is?
ClayPerrine
post Nov 28 2004, 10:08 AM
With that setup, just put the 19mm master cylinder into the car. Your brakes will be fine.
- Lo-Fi Version Time is now: 8th July 2025 - 03:29 PM
