Another productive weekend |
watsonrx13 |
Nov 28 2004, 05:07 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I completed prepping the rear trunk for painting.
Here's the pic after removing the seam sealer and the start of the day. 1 0f 3 Attached image(s) |
watsonrx13 |
Here's the after pic.
2 0f 3 Attached image(s) |
watsonrx13 |
Nov 28 2004, 05:08 PM
Here's another pic. The gray areas is AllMetal that I used to cover the minor rust converted areas.
3 of 3 Post #600 Attached image(s) |
Allan |
Nov 28 2004, 05:15 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
You did all that with a wire brush? Man that seam sealer gets everywhere when you brush it out. I just did about 2 feet of it and it was all over.
URY914 |
Nov 28 2004, 05:36 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,116 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
How come your trunk is different than mine?
Good job Rob. (IMG:style_emoticons/default/biggrin.gif) Paul |
watsonrx13 |
Nov 28 2004, 06:22 PM
Thanks Paul. If you ever decide to actually keep the metal in your car, call me and I can show you how to 'restore' it.... (IMG:style_emoticons/default/biggrin.gif)
BTW, you have moved from a f/g animal, to a tube-frame animal, good luck with the 'diet'. (IMG:style_emoticons/default/smoke.gif) Headrage, I used a wire-wheel to remove the seam-sealer (BTW, it creates 'strings' and goes everywhere), then used aircraft stripper to remove the rest of the paint. |
Qarl |
Nov 28 2004, 06:43 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
xsboost90 |
Nov 28 2004, 06:48 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
i love productive weekends...of course this weekend i had to work on the "other" car to get it going which included a clutch master and welding the exhaust up in a spot where it cracked...good to have things done though.
Attached image(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 02:58 PM |
